-   -   flickering light bulb when switched off (http://www.diychatroom.com/f18/flickering-light-bulb-when-switched-off-74834/)
debiasio 06-28-2010 05:11 AM
We have a incandescent ceiling light bulb in one of our extra bedrooms that flickers even when it is switched off. It happens with no particular frequency, and is most noticeable at night. I figure someone has miswired the switch...maybe switching the neutral wire instead of hot?
oberkc 06-28-2010 05:56 AM
My first inclination is to suspect a faulty switch. How old is the switch?
While a potential safely issue, I do not believe that switching a neutral will cause this problem. A loose wire on the switch may cause flickering when on, but I would not expect flickering when off due to a loose wire.
debiasio 06-28-2010 06:24 AM
not sure exactly how old it is. We just moved in a week ago. The house was built in 1948 so I'm guessing that the switch is old, even if it had been replaced since the house was built.
oberkc 06-28-2010 07:47 AM
I have replaced a couple of switches for intermittent/flickering lights. The age of your electrical system makes me continue to suspect this is your problem. Can you hear any noise from your switches? Arcing-type noise or buzzing?
Also, replacing a switch is pretty easy and inexpensive, so I tend to do this as a method of troubleshooting.
DangerMouse 06-28-2010 08:18 AM
Old switch would be my first guess as well. Easiest to replace and find out too!
(cut the power first, of course)
DM
debiasio 06-28-2010 08:26 AM
I think there is a mix of both aluminum and copper wiring. I really should have an electrican take a look at the overall system, but I don't have too much money to throw around. At the same time, I want to know of any safety concerns.
I just tried turning the light on and did hear a crackling sound coming from the switch. The light briefly turned on and then turned off again. Sounds like I'll be replacing it this evening. Thanks for the help!
DangerMouse 06-28-2010 08:50 AM
I'd cut the power to it until you can swap it out if that's possible.
DM
Red Squirrel 06-28-2010 09:24 AM
I'd suspect the switch as well, or maybe somewhere there is a lose wire that occasionally touches the box completing the circuit, but wires don't just move on their own, so I can't see how it would be that.
mikewr 06-19-2012 08:15 AM
flickering lights after replacing fixtures
Replaced all the fixtures outlets and switches in the family room during a remodel. My new fixtures have CFLs, and with the switch off, they flicker. After all the usual trouble-shooting, it turn out to be the new RF switch that could give me 3 way switch capabilities without running wires. Turns out the new RF switch isn't compatable with CFLs. So, looks like I'll need to run some wiring.
Seattle2k 06-19-2012 05:12 PM
Or get the appropriate RF switch. :wink:
