Flickering LED Light - Electrical - DIY Chatroom Home Improvement Forum
Old 06-10-2012, 10:40 PM   #1
I have a new Apartment/Garage that I have just finished and it is a very energy efficient building because of the envelope wall and roof system and the use of all LED lighting.
I would like to know if anyone can tell me that if a LED light is flickering is it using more energy than it is supposed to or is it OK ?
The light in question is in a Coach Light on the front wall and has 4 / 2 watt candelabra bulbs with dawn to dust filter.
I have had the power on for 10 days now and I have only used 177KW, the building is over 2000sq ft and I have the garage cooled also with LG Mini-Split 3 / 9000 BTU units and the building system has no attic so the area cooled is 20 feet tall at the peak...
Any help on the LED Flicker would be greatly apperciated...
Kelly Moore
iGreen Construction, Inc.
kelly42 is offline   Reply With Quote
Old 06-11-2012, 06:51 AM   #2
dmxtothemax's Avatar
Rewards Points: 5,102
NO !
Flickering uses less power.
Why is it flickering ?
What is it controlled by ?
Is it controlled by a dimmer ?
dmxtothemax is offline   Reply With Quote
Old 06-11-2012, 07:08 AM   #3
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Flickering is a broad term that has different meanings to different people.
Describe the flicker. Are there other coach lights (exactly the same) working fine? Where is the photocell? Is the fixture a LED fixture, or are you just using LED lamps?
Old 06-11-2012, 10:45 AM   #4
Flickering LED
There are 4 lamps per fixture, not an LED fixture, one or two of the 4 blinks and jumps like it does not get enough energy to lite properly. The bulb is screwed into the photocell and all 4 bulbs have a cell but not all blink...
It is kinda neat, looks like a gas lamp from far away. Just wonder if I am wasting extra electricity?
Kelly Moore
lGreen Construction, Inc.
flickering light bulb when switched off debiasio Electrical 9 06-19-2012 06:12 PM
How many wires can be tapped into a light fixture? JayBird Electrical 6 07-11-2011 03:44 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Marmoleum repairs muggyfrost Flooring 8 10-16-2008 09:19 PM
