Old 05-22-2012, 07:08 PM   #1
flickering fluorescent fixture?
The inlaws bathroom has (2) 24" fluorescent tubes in the celing.. About a year ago they started having problems, they bulbs seem to burn out once a month and they flickered alot, I finally got around to installing a new fixture and new bulbs in there, I turned it on and it seemed to work great for about a week and now its doing the exact same thing again. I dont have the time to keep messing with it hoping things work.. The house is 40-ish years old and I am guessing it could be a wiring problem but not sure how to really test that one out.. Also this is not what I consider a "wet" location, it is just a toilet and sink, no shower or bath..
Any idea on what I should be looking into or replacing??
cbzdel is offline   Reply With Quote
Old 05-23-2012, 12:26 AM   #2
" Euro " electrician
frenchelectrican's Avatar
Two thing will come to my mind so I will lay out the two cases to see which one will suit your situation.
Situation A ) have older romex cable without ground conductor.
This is common on older home when they were not rewired for long time and for 40 ish year old home you may I say may have a ground wire in one of the romex but I doubt that unless it is in bathroom or kitchen then I will say a 50/50 chance unless it was rewired for some reason for last 20 years.
Situation B ) if you have lighted switch handle that may cause the issue and if you have electronic ballast this will kill it pretty fast but magantic it should not be a issue.
Can you post a photo of what the wiring look like one of us can able indentify it quick.
Merci,
Marc
Old 05-23-2012, 09:05 AM   #3
Check the voltage being supplied to that fixture. Problems with wiring elsewhere could result in abnormal voltage that in turn will shorten the life of the fixture and the lamps (tubes).
The disadvantages of crab apple trees. In summer, the apples are too sour to pick and eat. In winter the birds come and leave dropping all over the place.
Wiring fluorescent fixture to ceiling box Richo Electrical 12 08-05-2010 07:19 PM
No ballast in 48 inch fluorescent fixture. Timster Electrical 16 06-10-2010 05:02 AM
Motion sensor & fluorescent fixture issue trclac Electrical 5 05-10-2010 11:42 AM
4 tube fluorescent fixture with two bulbs? dyeager535 Electrical 2 02-02-2009 06:51 PM
Fluorescent fixture not working hgiljr Electrical 6 05-25-2008 12:20 PM
