Flickering Flourescent, Bad Ballast? - Electrical - DIY Chatroom Home Improvement Forum
Old 01-28-2013, 03:05 PM   #1
Rewards Points: 83
flickering flourescent, bad ballast?
Hi,
Basic builder flourescent 4 bulb kitchen light was flickering...was dim...then would go bright, etc. I took the cover off and all four lights were working but the outer two were dimmer than the inner two.
I swapped working bulbs with the outer sockets...now neither outer bulbs do not light at all, inner two work fine.
When they say "ballast" is there more than one? Could the outer two be wired together and the inner two wired together?
I had a T8 bulb, F32, F32, and F32...I thought I could use both, maybe I created stress on the fixture by mixing types?
T8...skinny bulb, F32...fatter.
It seems strange it finally gave up working when I finally investigated, but stranger things have happened.
Thanks!
http://progresslighting.com/beta_pro...uct=P7280-60EB
D270 is offline   Reply With Quote
Old 01-28-2013, 03:18 PM   #2
Rewards Points: 254
I would think it would be a 4 bulb ballast unless they got 2, 2 bulbs in there, just pop the cover off and see. If its a T8 ballast use T8 bulbs when you replace it.
pwgsx is offline   Reply With Quote
Old 01-28-2013, 04:22 PM   #3
Electrical Contractor
jbfan's Avatar
Rewards Points: 380
F 32 is the wattage rating.
You either had T-8 lamps or T-12 lamps, and you can not mix them.
Older 4 lamp fixtures had 2 ballast, one for the inside pair, and one for the outside pair.
Remove the cover and read the types of lamps the ballast are rated for.
Old 01-28-2013, 06:45 PM   #4
Rewards Points: 83
thanks, so there are two ballasts...explains why the outside ballast is going bad. this is also where I mixed the two types.....ouch.
flourescent lamp ballast replacement pmstrsn Electrical 3 10-27-2012 11:14 PM
Ballast for flourescent bulb chshininc Electrical 4 03-28-2012 12:54 PM
flourescent ballast rating Rsparky1968 Electrical 0 04-24-2011 02:05 PM
How to install a new T-8 Ballast in a flourescent light T-12 fixture ejkia Electrical 12 10-26-2010 12:10 AM
flourescent lights flickering ugabulldog Electrical 6 08-31-2008 10:49 AM
