Flexible Stranded Cable For Generator Inlet - Electrical - DIY Chatroom Home Improvement Forum
Old 03-12-2013, 06:44 PM   #1
flexible stranded cable for generator inlet
I added a generator inlet and service disconnect to the outside of my house connecting to an existing inside wiring cable on the back wall. I used waterproof outdoor cable which is flexible and stranded and a friend questioned that this could be against the electrical code, that he would have used solid cable within a PVC conduit. I think I could have mounted the inlet directly at the spot where the inside wiring exits, and strung up the whole length of flexible cable as a generator extension cord. Since what I did should be an improvement over that, I don't quite understand what would be wrong with what I did. Also since this is a generator inlet circuit that is on an interlocked breaker, and will never be powered up except by the generator, during a power outage, I thought I learned that there were additional leniencies including to permit running the cable in a less than craftsman-like way. Any thoughts from someone who knows the code would be very much appreciated.
rob613 is offline   Reply With Quote
Old 03-12-2013, 06:47 PM   #2
Rewards Points: 13,300
#1 Go back and add your location to your profile.
Just go to Quick links and edit.
Old 03-12-2013, 06:47 PM   #3
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Exactly what type of cable did you use?
Old 03-12-2013, 06:59 PM   #4
cable type
I used 10 gauge 4 conductor cable within a rubber housing which says it is waterproof and good for 600V. I used one long piece which has aluminum strands within a yellow jacket to go from a weatherproof junction box, using wire ties to the inside wiring, to the service disconnect, which is a single 30A breaker external box which is fine for either solid or stranded wire. I used a shorter piece of identically rated but copper cable within a black housing to feed this panel from the generator inlet's 30A twist lock. I also have a short generator extension cord which will connect to the inlet from my generator's 20A twist lock which is protected by the generator's 20A breaker.
I am in Northern New England.
Old 03-12-2013, 07:11 PM   #5
E2 Electrician
Take a picture...
Old 03-12-2013, 07:17 PM   #6
Originally Posted by stickboy1375 View Post
Take a picture...
A close up picture of the label on the cable jacket? Or the overall outside view of how I ran the cables?
Just to clarify my question, I'm just trying to find out if stranded cable is prohibited for use between house wiring and a generator inlet screwed to the side of the house for rare use.
Old 03-12-2013, 07:18 PM   #7
E2 Electrician
I just was curious about the overall setup on this...
Old 03-12-2013, 07:53 PM   #8
Electrical Contractor
jbfan's Avatar
Rewards Points: 258
Sounds like it may be SO cord!
jbfan is online now   Reply With Quote
Old 03-12-2013, 07:54 PM   #9
E2 Electrician
Thats what im thinking...
Old 03-12-2013, 09:57 PM   #10
Licensed electrician
Rewards Points: 1,296
Flexible cords are not to be used in the manner you described if I understand your setup.
I doubt the conductors are aluminum.
stickboy1375 (03-13-2013)
sound out of cable box amakarevic Home Theater 11 05-18-2012 11:26 AM
Is Tray Cable acceptable for Residential use? MisterSteve Electrical 43 02-21-2012 01:35 AM
Evaluating a kinked cable dave11 Electrical 5 05-09-2010 11:20 AM
Running Sky+ cable bookersbeauty Electrical 1 04-09-2009 08:12 PM
Protect Cat6 cable near AC Power Cable? mfleming Electrical 5 10-31-2008 10:04 AM
