Flexible Metal Conduit Fitting To Keep Cable From Getting Cut - Electrical - DIY Chatroom Home Improvement Forum
Old 01-31-2014, 08:04 AM   #1
From Philadelphia
Rewards Points: 289
Flexible metal conduit fitting to keep cable from getting cut
I have some 1/2" "Greenfield" flexible metal conduit. I cut it with my Wiss sheet metal sheers. However, it leaves a nice sharp point that, when I feed the cable through, it nicks the outer sheathing, and I don't like that. Is there a special fitting to prevent this? Any other recommendations for working with flexible metal conduit, i.e. cutting it, etc.?
hellohello is offline   Reply With Quote
Old 01-31-2014, 08:18 AM   #2
seansy59's Avatar
Rewards Points: 258
You're looking for an "anti-short" bushing
http://www.homedepot.com/p/Halex-3-8...5401/100170558
seansy59 is offline   Reply With Quote
The Following User Says Thank You to seansy59 For This Useful Post:
hellohello (01-31-2014)
Old 01-31-2014, 08:58 AM   #3
From Philadelphia
Rewards Points: 289
Perfect, thanks!
Old 01-31-2014, 10:43 AM   #4
Rewards Points: 808
Why are you running cable through greenfield?
IslandGuy is offline   Reply With Quote
Old 01-31-2014, 10:54 AM   #5
Licensed electrician
Rewards Points: 1,744
Greenfield does not use redheads. The connector is the smooth edge.
Old 01-31-2014, 11:34 AM   #6
Master Electrician
Rewards Points: 3,916
Jim, I was under the impression that MC was exempt from redheads. Greenfield too?
brric is online now   Reply With Quote
Old 01-31-2014, 11:53 AM   #7
From Philadelphia
Rewards Points: 289
Unfinished basement needed a GFCI. So I ran the Greenfield along the foundation wall. What, was this wrong or something?
What do you mean "the connector is the smooth edge"?
Old 01-31-2014, 12:04 PM   #8
Bricc, I have never seen nor heard of anyone using or requiring a redhead for Greenfield. It was always just a Greenfield connector. Correct, MC does not require redheads unlike AC that does.
To OP, what are you using to connect the Greenfield to the box?
The Following 2 Users Say Thank You to Jim Port For This Useful Post:
brric (01-31-2014), mpoulton (01-31-2014)
Old 01-31-2014, 12:17 PM   #9
From Philadelphia
Rewards Points: 289
At the box, I'm using a "flexible metal conduit squeeze connector", like this: http://www.homedepot.com/p/Halex-1-2...205B/100174806
But my Greenfield is only covering a couple feet of cable from the unfinished ceiling down the wall. The rest of the cable is in the unfinished ceiling, so does not require conduit. At that point at the top of the wall where my conduit stops but the NM 14/2 keeps going to another box, what else am I supposed to use to keep the sharp end of the Greenfield from slicing the cable when feeding it through if a redhead isn't required? By the way, I'm assuming a redhead is an anti-short bushing.
Old 01-31-2014, 01:32 PM   #10
A redhead is the antishort bushing.
This is the connector style I am more familiar with
If you are worried about the threads just add a plastic bushing over the threads.
BTW, the flex is not a listed means against physical damage.
brric (01-31-2014)
Old 01-31-2014, 01:37 PM   #11
From Philadelphia
Rewards Points: 289
Yup, that picture you posted is exactly what I used and what I posted a link to in my previous post.
Old 02-03-2014, 09:22 AM   #12
Rewards Points: 766
you should use that to protect inside cable
http://www.alpinebuildingsupply.com/...ctCode=6946362
carmusic is offline   Reply With Quote
CAT6 Brand and Through metal conduit. jman2012 Electrical 17 10-06-2013 09:32 AM
pulling thick cable through conduit practices jackwashere Electrical 22 09-27-2013 05:59 AM
Running cable in conduit Audiotekm Electrical 10 11-09-2011 10:46 PM
SubPanel-NM Cable in Conduit? blankcek Electrical 9 06-24-2008 10:41 AM
pulling wire through old flexible conduit cbray Electrical 1 05-20-2005 03:55 PM
