Flex Outlets, How Do Y'all Cope Without These? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-07-2012, 12:52 PM   #1
Flex outlets, how do y'all cope without these?
Semi-serious question:
I'm a transplanted Brit into Texas, EE (Electronics) and have done a fair amount of electrical re-structuring in my UK life.
Dabbled a little bit here and been often infuriated at how things that I came to rely on in the UK are simply unheard of here.
Case in point, heated towel rail install:
Towel rail comes with 1/2 mile of flex and moulded plug.
GFI outlet is ~2' from towel rail.
Simple, I think: cut of moulded plug, install flex outlet.
For those not familiar, in the UK it's one of these:
http://compare.ebay.com/like/3006787...Types&var=sbar
Hmm.. no such thing available.
Ok, no idea why, the only other option is to cut off wire and put on re-wireable plug. Are you serious? The only such beasts available wouldn't look out of place in the 1800s!
So, what do y'all do for a situation like this?
TexasPenguin is offline   Reply With Quote
Old 12-07-2012, 12:57 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 254
Roll the cord up and use strap ties to hold it together!
Old 12-07-2012, 02:02 PM   #3
Yep, done that. Doesn't it look good!
Old 12-07-2012, 02:10 PM   #4
Rewards Points: 77
I had never heard of these before, but now I wish I could buy them!
patented is offline   Reply With Quote
Old 12-07-2012, 02:27 PM   #5
See if you can replace the entire cord assembly. It may be easy. They also make replacement ends that look good, but you have to look for them.
Canadian tire has a nice one.
sparkyjake is offline   Reply With Quote
The Following 2 Users Say Thank You to sparkyjake For This Useful Post:
NJMarine (12-08-2012), TexasPenguin (12-07-2012)
Old 12-07-2012, 02:36 PM   #6
Yeah, I guess that is the best option, thanks for the suggestion.
Old 12-07-2012, 02:39 PM   #7
Well, you could, of course, in this internet age.
But, like me, putting 'em in might be a mistake when you come to sell your house .
Not to mention the fact that you'd need the UK sized box and the neon would be a bit dim!
Old 12-07-2012, 02:49 PM   #8
Special User
Rewards Points: 1,230
Crap, me too!
I'm guessing the NEC doesn't like mixing permanent outlets with temporary device cords.
Hm, how about one of those digital TV wall mount boxes. Some of those have a opening (normally for HDMI) so you could stuff the excess power cord inside the wall, then stick the towel rack's stock molded plug into the recessed outlet. Hopefully you can find one with a cover plate to hide everything behind.
The above post is for entertainment purposes only. Its contents may, and probably will, lead to legal liability and damage or loss of property, life, or limb. Use at your own risk.
tylernt is offline   Reply With Quote
Old 12-07-2012, 05:20 PM   #9
Oso954's Avatar
Rewards Points: 772
No power cords in walls.
Oso954 is online now   Reply With Quote
Old 12-07-2012, 05:25 PM   #10
Special User
I agree that cords should not go through walls. In this case though, you're going in and coming out the same hole. A fine point to be sure...
EDIT: Oops, I just realized that if there were insulation in the wall, heat could build up in the appliance cord and pose a fire risk.
But an uninsulated stud bay... ok yeah I admit it's still iffy.
Old 12-07-2012, 05:29 PM   #11
TTW
TTW's Avatar
I think you meant 1/2 Meter? Not 2,640 feet
#1 - If you don't know what you're doing - get a licensed electrician!
#2 - If you follow my advice and something bad happens see # 1
Electricity bites hard, and it could be the last thing you feel... Good Luck!
TTW is offline   Reply With Quote
Old 12-07-2012, 05:34 PM   #12
No, I meant 1/2 mile - I was being facetious!
(But don't get me started on why the USA loves to use the least useful unit of measure - I mean, acre-foot, really?)
The Following User Says Thank You to TexasPenguin For This Useful Post:
TTW (12-07-2012)
Old 12-07-2012, 05:38 PM   #13
jbfan's Avatar
Rewards Points: 254
I never said it would be pretty, but unless you change the cord, thats about all you can do.
Old 12-07-2012, 05:45 PM   #14
TTW
TTW's Avatar
Is the heated towel rail 120 or 220v?
Old 12-08-2012, 08:22 AM   #15
120, standard US molded plug.
Love your avatar, by the way!
2 wire outlets: connect neutral to ground? border collie Electrical 19 04-12-2013 01:29 PM
Gfi outlets keep tripping but not constantly INEEDHELPPLZ1 Electrical 22 09-30-2011 09:28 AM
Grounding outlets... bigdaddyII Electrical 12 08-28-2011 03:22 PM
Supplemental Outlets in 1950's House Perry401 Electrical 2 05-01-2011 09:49 PM
outlets work, but barely (?) joeyboy Electrical 7 08-27-2008 09:37 AM
