Flex Length Per NEC - Electrical - DIY Chatroom Home Improvement Forum
Old 09-18-2014, 12:42 PM   #1
Rewards Points: 49
Flex Length per NEC
I was intending to install only 6 feet of 3/4 non metallic flex (grey pLastic/pvc) but I thought I read somewhere here that the length is not necessarily limited to 6 foot.
I would like to install 25 feet of flex under my deck from house (gfci panel) to spa control panel.
I will have 3-#6 in the cable---for 60 amp 220 to a Sundance Optima.
Is that ok?
what would be the "support" requirements?
DaveMcSF is offline   Reply With Quote
Old 09-18-2014, 12:59 PM   #2
Rewards Points: 6,652
The disconnect from the spa is what matters. I would just run the Schedule 40 under the deck, paint it after you get it hung, the color of the deck, then place the disconnect within six feet of the spa.
Old 09-18-2014, 12:59 PM   #3
Oso954's Avatar
Rewards Points: 1,108
You are allowed 6 ft outside the spa, plus the amount under the spa.
See Posts 5-7 in your previous thread.
New Sundance Optima Spa connection
Oso954 is online now   Reply With Quote
The Following User Says Thank You to Oso954 For This Useful Post:
gregzoll (09-18-2014)
Old 09-18-2014, 01:08 PM   #4
Rewards Points: 49
Got it ---thank you guys for the re-confirmation!
Old 09-18-2014, 01:44 PM   #5
No problem. Just remember to leave a drip loop under the disconnect, where you run the flex into it.
Old 09-18-2014, 02:01 PM   #6
Rewards Points: 49
You know the second I read your advice--"drip loop"---I visualized a "P" trap----and water dripping from the lo point---thank you again---I will do that!
Tags
flex , nec , optima
Different temperature rooms ( flex ducting ) Iceman1982 HVAC 1 12-19-2012 04:45 AM
should I leave flex conduit in the walls? fabster Electrical 1 11-10-2012 10:36 AM
Duct length - is there a "limit"? raff98 HVAC 8 08-01-2010 04:10 PM
Rerouting 6" Flex - quick question Satori HVAC 1 07-21-2010 06:31 PM
Types of flex duct and support method wingam00 HVAC 1 06-04-2005 01:12 PM
