Flex Conduit For LV Or Coax? - Electrical - DIY Chatroom Home Improvement Forum
Old 03-20-2010, 02:09 PM   #1
tonyBagadonuts's Avatar
Rewards Points: 29
Flex Conduit for LV or coax?
I am doing the prewire in my new office at work and have some 1" metal flex conduit. My question is will this conduit cause any problems using it for low voltage, coax for cable, cat5 for phones, or any networking cables for my comps. I know "smurf" is cheaper but I already have this. Any help appreciated,
Tony
tonyBagadonuts is offline   Reply With Quote
Old 03-21-2010, 09:39 AM   #2
Electrician
SD515's Avatar
Rewards Points: 504
I don't know of any problems with using it for low voltage, other than it's not any fun pushing wires through it. Suggest loading it with a pull string or 2 before final installation to make it easier.
Kyle
Old 03-22-2010, 06:07 PM   #3
That's going to be pretty narrow for anything more than 3-4 pull's. For sure run a fish (pull string). Cat-5 et al. has a nasty habit of wrapping around each other in the conduit.
clb2010 is offline   Reply With Quote
Old 03-22-2010, 07:34 PM   #4
DIYer
I don't want to be "that guy" but real electricians are supposed to do all commercial work.
Gigs is offline   Reply With Quote
Old 03-22-2010, 07:38 PM   #5
While cat-5 for computers etc can be considered "low voltage" since there is are 5v going across the wires as a part of the 802.3 standard as long as (s)he is not pulling power cables it shouldn't be a problem. If you are running power or HV then *DO NOT* put them in the same conduit.
Old 03-23-2010, 02:43 AM   #6
Rewards Points: 29
Let me try to clear up a couple things:
My main concern would be if I would have any shielding issues or interferance from the metal. Would never mix say cat5 with THNN or the like.
This prewire I am doing is not for anything other than phone, comp network , cable, phones........
Thnaks for the responses. Looks like I may just do smurf tube anyway
Tony
Old 03-23-2010, 02:51 AM   #7
Rewards Points: 29
In the state of Arizona, of which I am a resident, an owner may do electrical work to their own building. Keep in mind that it must pas the same inspection that would be given to a "real" electricians work. I recently installed a new 200A entrance at this office myself. It was inspected by a city building inspector and passed. I am a little above novice level and will tackle about anything ..... I just do alot of research.
Tony
Old 03-23-2010, 08:12 AM   #8
Electrician
Rewards Points: 794
I've done data installs useing 3/4" EMT instead of smurf tube and as far as i know there was no problems with interferance, so your metal flex should be fine.
darren is offline   Reply With Quote
Old 03-23-2010, 09:12 AM   #9
Tony
Though it generally isn't done you shouldn't have any shielding/interference from the metal itself
Old 03-23-2010, 10:08 AM   #10
Rewards Points: 29
Thanks all very much for the input. I will try using it for many phones & coax cables for TV/Internet.
Always good to know I can get good info here
Tony
PVC conduit - custom offset or bending tns1 Electrical 25 08-29-2011 05:56 PM
Chicago Conduit Rules Wrigleyville Electrical 6 01-28-2010 06:49 PM
Sheathing/siding around conduit destroyer427 Building & Construction 1 10-20-2009 05:25 PM
What should I use to sexure flex conduit... rgsgww Electrical 19 03-20-2009 12:37 PM
ground wire in rigid conduit measure thrice Electrical 3 02-03-2009 05:25 AM
