Old 02-04-2009, 05:48 PM   #1
flatscreen TV install
I find out there is a recessed "clock hanger" recptacle I can use for the plug of the TV. I also found out there is low voltage face plate that lets
the A/V cable come out of the wall, using a low voltage open back box to mount the plate.
That's 2 holes and 2 face plates, does anyone know there are better options or fixtures to get the low voltage and line voltage to the TV?
DIYGST is offline   Reply With Quote
Old 02-04-2009, 06:17 PM   #2
Electrical Contractor
wirenut1110's Avatar
Send a message via AIM to wirenut1110
Something like this?
http://www.smarthome.com/86518B/Rece...617-REB/p.aspx
or maybe this? http://cableorganizer.com/arlington-...Best%20Matches
wirenut1110 is offline   Reply With Quote
Old 02-04-2009, 06:23 PM   #3
hi those look great.
Can you tell me if that little divider in the middle separating the Line and Low voltage connection?
Old 02-04-2009, 06:29 PM   #4
Dual Gang Recessed Electrical Box
  • Dual voltage allows for power and low voltage use with included divider
Old 02-04-2009, 06:40 PM   #5
Thanks.. can you tell me if it's OK to run romex and low voltage (cat5, coaxial) through the same hole in the header?
Old 02-04-2009, 06:48 PM   #6
Nah , that wouldn't be a good idea. It would delete the purpose of the separation.
Old 02-04-2009, 06:53 PM   #7
Electrician
Its perfectly fine, and allowed by code.
chris75 is offline   Reply With Quote
Old 02-04-2009, 07:00 PM   #8
Never said it wasn't "allowed", I just prefer to keep the 2 seperated. Personal preference that's all.
Old 02-04-2009, 07:02 PM   #9
Electrician
Well, you should say so then. Dont make the OP do more work than needed...
Old 02-04-2009, 07:05 PM   #10
Well ok then, I'm sorry
Old 02-04-2009, 07:06 PM   #11
Thanks guys you are great help, I am set
Old 02-04-2009, 07:13 PM   #12
Electrician
I am just teasing you...
Old 02-04-2009, 07:14 PM   #13
Electrician
Enjoy your TV.
Old 02-04-2009, 09:35 PM   #14
Now, if only there was something worth watching on that expensive TV
FW
KE2KB is offline   Reply With Quote
Mounting a flatscreen TV on a sheetrock wall TanMan Building & Construction 14 02-16-2009 05:26 PM
When to install tile flooring? MT Stringer Remodeling 4 10-28-2008 09:49 PM
Preparing to install Kerdi on bathtub surround DIY-Renovator Flooring 18 07-17-2008 11:42 AM
