-   -   flatscreen TV install (http://www.diychatroom.com/f18/flatscreen-tv-install-37625/)
DIYGST 02-04-2009 05:48 PM
I find out there is a recessed "clock hanger" recptacle I can use for the plug of the TV. I also found out there is low voltage face plate that lets
the A/V cable come out of the wall, using a low voltage open back box to mount the plate.
That's 2 holes and 2 face plates, does anyone know there are better options or fixtures to get the low voltage and line voltage to the TV?
wirenut1110 02-04-2009 06:17 PM
Something like this?
http://www.smarthome.com/86518B/Rece...617-REB/p.aspx
or maybe this? http://cableorganizer.com/arlington-...Best%20Matches
DIYGST 02-04-2009 06:23 PM
hi those look great.
Can you tell me if that little divider in the middle separating the Line and Low voltage connection?
http://images.cableorganizer.com/arl...mponents-s.jpg
wirenut1110 02-04-2009 06:29 PM
Dual Gang Recessed Electrical Box
  • Dual voltage allows for power and low voltage use with included divider
DIYGST 02-04-2009 06:40 PM
Thanks.. can you tell me if it's OK to run romex and low voltage (cat5, coaxial) through the same hole in the header?
wirenut1110 02-04-2009 06:48 PM
Nah , that wouldn't be a good idea. It would delete the purpose of the separation.
chris75 02-04-2009 06:53 PM
Its perfectly fine, and allowed by code.
wirenut1110 02-04-2009 07:00 PM
Never said it wasn't "allowed", I just prefer to keep the 2 seperated. Personal preference that's all.
chris75 02-04-2009 07:02 PM
Well, you should say so then. Dont make the OP do more work than needed...:)
wirenut1110 02-04-2009 07:05 PM
Well ok then, I'm sorry:surrender:
DIYGST 02-04-2009 07:06 PM
Thanks guys you are great help, I am set
chris75 02-04-2009 07:13 PM
I am just teasing you... :)
chris75 02-04-2009 07:14 PM
Enjoy your TV. :)
Ultrarunner2017 02-04-2009 09:35 PM
Now, if only there was something worth watching on that expensive TV:laughing:
FW
