Originally Posted by stang93
Can i just cut-out a hole wear i want the outlet install a box and recepticle and run the romex down to the existing outlet?
This is basically all it is, you will need a cut in box and "F" straps to secure it. trace the box and cut make sure you don't cut out the flaps that are meant to keep the box from falling inside the wall. Drop the romex down to the existing box. put the box in and secure it. The most difficult part might be getting the wire into the existing box.
If i do that, do i splice into the wires on the existing outlet or double up on the outlet? im lost  thanks
You should put wire nuts in (if they aren't already there.) All the blacks should connect, all the whites should connect and all of the grounds (bare wire) should connect, with short pieces going to the outlet for each one.
