Old 11-23-2009, 09:35 AM   #1
Flat screen tv causes gfi to trip
Hi, we bought a new flat screen tv a few years ago. I installed a new circuit for it and used a gfi outlet. It is a dry location and maybe overkill but i had an extra gfi anyway.
Every now and then we are watching tv and you will hear a snap sound and the gfi will trip. Reset the gfi and everything is fine for a while. I actually put up with this for a long time and then we dicided to replace the tv with a larger one. To my surprise the gfi tripped with the new tv. I have never heard that a gfi for a tv would cause nuisance tripping of the gfi. Has anyone else heard of this, or do you think the gfi is bad?
SS396 is offline   Reply With Quote
Old 11-23-2009, 01:48 PM   #2
There may be built in power surge protection or you may have this on a power surge strip.
Surge protection works by shunting the power to ground in the case of a power surge. This could trip the GFCI.
And power surges may happen every once and a while on a regular basis. You wouldn't even notice it.
GFCI's are intended to protect people from being electrocuted. This would be from hand held appliances, tools, etc. Or power cords. Or things in wet areas.
I would advise you to use a regular outlet for the TV as you are not handling it and I would not see a shock hazard with regular use.
Billy_Bob is offline   Reply With Quote
Old 11-23-2009, 02:34 PM   #3
It was a dark and stormy
Yoyizit's Avatar
Ditto.
flat screen outside? tripflex General Discussion 16 09-22-2009 05:06 PM
Glass mirror over fireplace, any ideas how to install flat screen TV? dynamo Building & Construction 1 07-25-2009 10:02 AM
Uneven Studs and mounting a Flat Screen -Please Help! SassyLilRedhead Home Theater 6 01-22-2009 10:33 PM
flat screen tv outlet stang93 Electrical 9 12-20-2008 02:55 PM
New to the site - Need help installing a 46" Flat Screen above Fireplace shawna Home Theater 2 11-26-2008 04:25 PM
