Fixture Whip - Electrical - DIY Chatroom Home Improvement Forum
Old 10-02-2010, 01:11 PM   #1
Fixture whip
I am adding a new bathfan and was wondering if I have EMT running up the wall to a box, and then transition to a Fixture Whip cable to the bath fan, does the metal fixture whip serve as a continous ground as if it was EMT 100% of the way?
timchi29 is offline   Reply With Quote
Old 10-03-2010, 08:09 AM   #2
Electrician
SD515's Avatar
Rewards Points: 504
Only if the fixture whip has a continuous bonding strip underneath the metal sheathing in contact with it. Check it's listing. Also you have to use the proper cable end-fittings that also have to be listed for use as the grounding requirement. If the cable has a separate green ground wire, it probably isn't going to have it's sheath rated as the ground, but the green wire would serve as your ground instead. You'ld have to check as to whether that wiring method is acceptable in your area.
Kyle
Old 10-03-2010, 08:38 AM   #3
Master Electrician
Rewards Points: 3,678
That's news to me.
brric is offline   Reply With Quote
Old 10-03-2010, 10:02 AM   #4
Electrician
SD515's Avatar
Rewards Points: 504
That's news to me.
Armored cable (AC), Southwire MC-AP wire has an internal bonding strip,
MC is also availible as HCF cable which has a bonding strip as well as a full sized ground.
Kyle
Old 10-03-2010, 01:04 PM   #5
Master Electrician
Ever hear of greenfield?
Old 10-03-2010, 03:42 PM   #6
I actually went with .5" Flexible metal conduit and installed (4)-#14.
http://afcweb.com/pdfs/liquidtuff/cu...x-rw-steel.pdf
Old 10-03-2010, 09:42 PM   #7
you can tell if u have emt, take off the lite switch plate and look into the box with a flashlite and see the conduits coming into the box. Or u can see the romexes or the flex conduit ucan determine this at this point.
Kirky is offline   Reply With Quote
Old 10-03-2010, 10:05 PM   #8
Kirky,
I know I have EMT, but the question is if the metal flex conduit i used from the EMT to the bath fan will still act as ground.
Old 10-03-2010, 10:34 PM   #9
" Euro " electrician
frenchelectrican's Avatar
Originally Posted by timchi29 View Post
Kirky,
The metal flex conduit will come in few diffrent class type.
BX will have interal bonding / grounding strip while the MC it will have a grounding conductor in there the reguar metal fexiable conduit do not have interal grounding so you have to pull the grounding conductor in there.
Merci.
Marc
New Member, New House Owner, New Light fixture kingston73 Electrical 3 09-19-2010 07:13 PM
Old house, having light fixture issues atomiclilly Electrical 6 12-03-2009 09:54 AM
Installing One Light Fixture Causes Another Not To Work pythagras Electrical 2 07-02-2009 09:15 PM
double-ended halogen fixture bulbs stop working watt-ever-ny Electrical 6 11-20-2007 06:25 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
