Fixture Box - Electrical - DIY Chatroom Home Improvement Forum
Old 03-31-2012, 05:36 PM   #1
fixture box
how to install fixture box without stud in dry wall
ashfaquechanna is offline   Reply With Quote
Old 03-31-2012, 05:45 PM   #2
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
You need one of these.It's referred to as an "old work box"
Cut a hole using the box as a guide,insert box tighten screws till box it secured to drywall.
sublime2 is offline   Reply With Quote
Old 03-31-2012, 07:18 PM   #3
Licensed electrician
Rewards Points: 1,494
The box shown above would be fine for a switch or receptacle. For a light fixture you need a different style and perhaps one with a bracket. Old work ceiling boxes are not rated for fixture support according to one manufacturer.
Old 03-31-2012, 08:34 PM   #4
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
If it is for a ceiling application.
This will work too;
This also comes in a plastic box.
Old 03-31-2012, 09:03 PM   #5
Rewards Points: 506
Do ceilings have studs?
Just playin...
The word "fixture" does imply a light.
jlmran is offline   Reply With Quote
Old 03-31-2012, 09:25 PM   #6
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Just playin...
Installing ceiling fixture with a metal junction box Romanuke Electrical 12 03-20-2011 02:37 PM
Hanging an overhead fixture jbcurrier Electrical 8 11-25-2010 11:19 AM
Installing One Light Fixture Causes Another Not To Work pythagras Electrical 2 07-02-2009 08:15 PM
double-ended halogen fixture bulbs stop working watt-ever-ny Electrical 6 11-20-2007 05:25 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 08:58 AM
