Fixing An Idiot Mistake - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-21-2013, 12:45 AM   #16
Child Alert! Pull Up!
fltdek's Avatar
Originally Posted by jbert78 View Post
If you are referring to the Orange Extension Cord that I mentioned then I found this when I was running my new line to the new lights.
Replace it at all cost! not worth the chance of knowing that the individual who used it has no clue! and if it is in a wall or ceiling, thats a big no no! As you will read on most if not all extension cords, they are clearly marked "for temporary use only"
fltdek is offline   Reply With Quote
Old 01-21-2013, 12:49 AM   #17
fltdek's Avatar
Yes my new lights that I installed work perfect. I can even get one of the two other lights to work, but am having trouble figuring out why this other light won't work. After getting one of them to work I used a Non-Contact Voltage Tester on the other and it shows that I'm getting power, but still nothing. Even tried changing the bulb!
Your NCV tester is prone to pick up what we sometimes refer to as "bleeding" from another source wire. They are not fool proof and can be misleading, most especially when multiple wires are run close together, or in a box. Don't rely entirely on it.
Old 01-21-2013, 12:49 AM   #18
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I'm guessing you are missing a neutral at that second fixture. I have no idea how this was originally wired as you cannot (legally get two switch legs out of a cable consisting of only 2 insulated conductors.
The only choices I can give you are:
1) run a new cable to the fixture that doesn't work
2) call an electrician to troubleshoot the problem
I highly suggest #2 because he can tell you if he sees any other dangerous violations. It sounds as you have some really jacked up stuff going on in there and they could possibly be a danger to your property or person.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
jbert78 (01-21-2013), NJMarine (01-21-2013)
Old 01-21-2013, 12:55 AM   #19
fltdek's Avatar
Absolutley agree, trying to do something on your own, is notable, saving your life is worth every penny spent. You must have to wonder, what other kind of half ass work did the former owner do? I'd have a difficult time sleeping at night.
The Following User Says Thank You to fltdek For This Useful Post:
Old 01-21-2013, 01:01 AM   #20
After seeing that Extension cord being used, I knew it was illegal and was going to replace it anyways. I know NCV tester is not totally reliable, but it did help. When there was no power going to the light, I got no beeping on the tester. I just use it for a quick test or double check there is no power. Thanks for the Help everyone. I'm going to run a new line for now and get a Licensed Electrician in here when I can afford one.
jbert78 is offline   Reply With Quote
Old 01-21-2013, 01:08 AM   #21
fltdek's Avatar
Be safe! Any other questions, be sure to post them here, we'll do what we can for you to your level of comfortness. There's no failure throwing in the towel and calling an electrician! Good luck!
Old 01-21-2013, 07:56 AM   #22
Rewards Points: 2,494
Still cannot understand how you have 2 lights(existing kitchen light and the mudroom light) controlled by 2 separate switches with only a 2 conductor cable W/ ground originating at the switch location. What was used for the switch leg for one of the lights??
hammerlane is offline   Reply With Quote
Old 01-21-2013, 08:49 PM   #23
dmxtothemax's Avatar
Rewards Points: 5,096
Three lights ?
Three wires ?
Where is the missing wire ?
Not including neutral and earth,
you need at least four wires !
1 - Main hot in.
2 - Feed to light -1.
3 - Feed to light -2.
4 - Feed to light - 3.
Minimum total = 4.
Maybe Nicoli Tesla instaled it !
Wireless power !
dmxtothemax is offline   Reply With Quote
Old 01-22-2013, 12:00 PM   #24
Originally Posted by dmxtothemax View Post
Three lights ?
Three wires ?
1 - Main hot in.
Minimum total = 4.
Wireless power !
I have all my lights working now cause I just ran a new line after chatting with k_buz and fltdek. When I took the 3 gang box out to run my new line, I used my iphone and took a picture on the inner wall and I was not missing any wires. I took the light down and saw they taped the neutral to be hot as an end circuit connection. k_buz thought someone installed it using the uninsulated ground as the hot, but that was not the case here. I don't know who did the electrical in this house before we moved in, but I'm going to find out.
Old 01-22-2013, 01:11 PM   #25
k_buz's Avatar
If the white was connected to the black of the fixture, what was connected to the white of the fixture?
How many cables were existing at the fixture before you added the new cable?
I will wait for these answers before I clarify what I actually thought.
Old 01-22-2013, 01:54 PM   #26
There were 5 wires! 3 from the light itself and 2 from the Romex cable. The ground was cut very short with to attach to. The white was connected to the black and the black was connected to the white. Does this make any since to you.
There was not even a box in the wall, just the wires and the bracket was held up by two drywall screws. I fixed that though.
Need URGENT help with question regarding fixing electrical panel in home asledge Electrical 66 02-22-2013 05:49 PM
Fixing my Durock Mistake ScubaGeekNC Flooring 12 05-24-2012 08:48 PM
Fixing a side gate.. ariscus99 General DIY Discussions 6 10-20-2011 06:34 PM
fixing a mistake igneous Painting 6 11-11-2010 08:31 AM
