Fixing A Flourescent Light Fixture - Electrical - DIY Chatroom Home Improvement Forum
Old 12-23-2011, 03:05 AM   #1
Question
Fixing a flourescent light fixture
Replacing the bulbs didn't work so I decided to replace the ballast (probably screwed up letting the thing flicker for days-- evidently that's bad).
However, having taken it apart, I notice something odd: when switch is on I get the expected 120 V from the two wires, but when it's off I get 40V AC-- now that shouldn't be, should it?
I'm assuming that this means that one of the switches (it's a 3-way pair of switches) is defective and should be fixed, but I thought I'd stop by here and run it by you guys.
Thanks!
Alai is offline   Reply With Quote
Old 12-23-2011, 11:10 AM   #2
Household Handyman
Rewards Points: 1,408
Just for clarification: A pair of 3-switches. That said, IF the switch controlling the particular light you are working on is in the "OFF" position, and it IS a 3-way switch, then YES you could possibly be getting some "backfeed" via the wiring for the switches. OR--if the controlling 3-way switch is backfed via another switch, then anything is possible. I prefer dedicated circuits for multiple switching devices.
Old 12-23-2011, 11:46 AM   #3
JOATMON
ddawg16's Avatar
Rewards Points: 1,112
If you are using a high impeadance meter, you are just picking up induced voltage....the moment you put a load across it, the voltage will drop to 0.
ddawg16 is online now   Reply With Quote
Old 12-23-2011, 12:13 PM   #4
I can pickup voltage on just about any wire that is a few feet long on my Fluke 88, and not a thing on my much cheaper and lower impedance DVOM.
Little things like this can sometimes cause issues with troubleshooting if you dont keep that in mind.
fuzzball03 is offline   Reply With Quote
Old 12-23-2011, 03:29 PM   #5
Electrician
Rewards Points: 770
Wow that could get expensive and fill your panel up very quickly.
darren is offline   Reply With Quote
Old 12-23-2011, 06:50 PM   #6
Thanks for the responses, especially ddawg16. I believe it's a case of stray (induced) voltage. Here's a primer for those interested:
http://support.fluke.com/find-sales/...01_ENG_B_W.PDF
I'm using an el-cheapo Chinese DMM. I connected a cell phone charger to the two leads while measuring, and the AC voltage went from 40V down to 4V.
I've finished replacing the ballast and it works great. Thanks, everyone!
Tags
3-way , flourescent , light switch
Please Help! 3 way switches controling 2 light fxtures. HelloMotto Electrical 52 11-05-2014 05:28 PM
Issues hooking up new light fixture ddzc Electrical 6 11-29-2010 08:19 PM
Relocating a light fixture Eclipse99 Electrical 5 02-27-2010 11:04 PM
Flourescent Fixture problem Steve-o Electrical 6 02-07-2010 04:09 AM
Multi-wiring one flourescent light fixture... cjkline83 Electrical 4 01-06-2009 09:50 AM
