-   -   Fixing a flourescent light fixture (http://www.diychatroom.com/f18/fixing-flourescent-light-fixture-127454/)
Alai 12-23-2011 02:05 AM
Replacing the bulbs didn't work so I decided to replace the ballast (probably screwed up letting the thing flicker for days-- evidently that's bad).
However, having taken it apart, I notice something odd: when switch is on I get the expected 120 V from the two wires, but when it's off I get 40V AC-- now that shouldn't be, should it?
I'm assuming that this means that one of the switches (it's a 3-way pair of switches) is defective and should be fixed, but I thought I'd stop by here and run it by you guys.
Thanks!
Thurman 12-23-2011 10:10 AM
Just for clarification: A pair of 3-switches. That said, IF the switch controlling the particular light you are working on is in the "OFF" position, and it IS a 3-way switch, then YES you could possibly be getting some "backfeed" via the wiring for the switches. OR--if the controlling 3-way switch is backfed via another switch, then anything is possible. I prefer dedicated circuits for multiple switching devices.
ddawg16 12-23-2011 10:46 AM
If you are using a high impeadance meter, you are just picking up induced voltage....the moment you put a load across it, the voltage will drop to 0.
fuzzball03 12-23-2011 11:13 AM
:thumbsup:
I can pickup voltage on just about any wire that is a few feet long on my Fluke 88, and not a thing on my much cheaper and lower impedance DVOM.
Little things like this can sometimes cause issues with troubleshooting if you dont keep that in mind.
darren 12-23-2011 02:29 PM
Wow that could get expensive and fill your panel up very quickly.
Alai 12-23-2011 05:50 PM
Thanks for the responses, especially ddawg16. I believe it's a case of stray (induced) voltage. Here's a primer for those interested:
http://support.fluke.com/find-sales/...01_ENG_B_W.PDF
I'm using an el-cheapo Chinese DMM. I connected a cell phone charger to the two leads while measuring, and the AC voltage went from 40V down to 4V.
I've finished replacing the ballast and it works great. Thanks, everyone!
