Fix Light Switch - Electrical - DIY Chatroom Home Improvement Forum
Old 01-16-2013, 06:56 AM   #1
Question
Fix light switch
Usually I can turn on the light by pressing down the switch, but somehow it doesn't work anymore. When I press down, it does not stay and bounds back. How can I fix this?
Please see attached photo.
Much appreciated.
smoyi is offline   Reply With Quote
Old 01-16-2013, 07:13 AM   #2
Master General ReEngineer
Bondo's Avatar
Rewards Points: 606
Ayuh,.... Replace it...
Bondo is online now   Reply With Quote
Old 01-16-2013, 07:16 AM   #3
How to replace it? can I get a new one from the shop? Thanks.
Old 01-16-2013, 08:10 AM   #4
Rewards Points: 1,442
You may or may not be able to find a switch exactly like that.
You will need to turn off the power, unscrew that switch from the wall, and measure the space and the spacing between the screw holes. Then find a switch that fits.
It is possible you will end up with a switch of a different style, for example with a toggle that flips up for on and down for off.
A few folks, I would guess those who built model ships and planes in an earlier life, may be able to dissect that switch and repair it.
Old 01-16-2013, 08:14 AM   #5
Electrical Contractor
kbsparky's Avatar
That looks like the type of switch used in Australia. Where in the world are you?
-KB
Old 01-16-2013, 03:29 PM   #6
I am in Australia.
Old 01-16-2013, 03:30 PM   #7
OK, I will try this.
Old 01-16-2013, 05:20 PM   #8
kbsparky's Avatar
Originally Posted by smoyi View Post
I am in Australia.
I thought so. Check with a local hardware store or supply house for a replacement switch. It should be an easy task to remove and replace it.
Be sure to switch off the main power before attempting to replace the switch.
Do they still have Mitre10 stores down there? Do they sell that sort of thing?
-KB
Wiring in a 4-way Switch RickSene Electrical 5 04-09-2013 08:25 PM
Hot wires on both sides of switch RedRumLoki Electrical 4 11-20-2012 10:37 PM
Replace bathroom light switch with dimmer switch ToddD Electrical 11 05-06-2012 06:58 PM
Motion Light tripping GFCI? Jonobp Electrical 5 09-07-2009 08:52 PM
Confused by switch w/indicator light install... WaldenL Electrical 7 08-29-2009 10:02 AM
