Fitting Wires In A Box. - Electrical - DIY Chatroom Home Improvement Forum
Old 03-07-2011, 10:23 AM   #1
Rewards Points: 262
Fitting wires in a box.
Wiring two switches with a single feed in a box. Switch 1 operates one outdoor light. Switch 2 operates two runs of undercabinet lights. Am using a standard double plastic old work box. Should I look for a deeper box or should all of this fit?
Jim F is online now   Reply With Quote
Old 03-07-2011, 10:26 AM   #2
I=E/R
a7ecorsair's Avatar
What size wire is being used and how many cubic inches is the box? The cu in should be embossed in the plastic box.
a7ecorsair is offline   Reply With Quote
Old 03-07-2011, 10:36 AM   #3
Licensed electrician
Rewards Points: 996
Unless you have extra cables in the box you should be well under the maximum capacity of the box. Provide the info Ae7 asked for and someone can confirm.
Old 03-07-2011, 09:02 PM   #4
Rewards Points: 262
Sorry, 14/2 and I believe it is a 25 cubic inch, does that sound right? This is the box http://electrical.hardwarestore.com/...ox-289470.aspx
And to add to the fun, the bottom wing snapped off twice while working the wires.
Old 03-07-2011, 09:22 PM   #5
I=E/R
a7ecorsair's Avatar
You are good for capacity.
The Following User Says Thank You to a7ecorsair For This Useful Post:
Jim F (03-07-2011)
Is this normal? 20A circuit 20A wires feed 15A wires walt1122 Electrical 14 02-06-2010 03:44 PM
Fitting dimmer switch to old electrical wiring hugomax69 Electrical 0 01-29-2010 08:40 PM
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 10:38 PM
Old house, new light fixture, too many wires Persephonee Electrical 3 01-15-2007 09:58 AM
