-   -   fitting security light using fused connection unit (http://www.diychatroom.com/f18/fitting-security-light-using-fused-connection-unit-165926/)
br3ttwilson 12-08-2012 02:02 PM
Hi guys.
Good looking forum here. i have tried searching for this with no luck.
My question is
i am looking to install a motion sensored security light outside. its a 150w halogen flood light.
my plan was to use a double socket outlet in my bedroom and drill directly behind to outside where the light will be fitted.
i will then feed the cable through and fit a dual gang box behind capable of housing 2 single sockets.
i was then going to fit a fused connection unit(13 amp but unsure of this correct rating as i read i should only need a 5a for 150w?) i was going to terminate the light along with the spare power feed to the fcu.
on the other side will be a single socket which will house the other power cable.
Will this work?
I have thought of of just feeding cable through and reconnecting plug and plugging into socket directly but i did not want this as i wanted it to be hidden.
I look forward to ur replies.
Regards
brett
joecaption 12-08-2012 02:14 PM
Nothing your suggesting sounds even remotly legal or logical.
Where do you plan on mounting this to the house?
Got a picture of the light fixture?
rjniles 12-08-2012 02:40 PM
What are you calling a "fused connection unit"? Are you in the USA?
br3ttwilson 12-08-2012 04:21 PM
As stated in my post i plan on drilling out directly behind where my double socket is located in my bedroom.
Its just a basic halogen flood light. am on my phone so can not upload photo.
Tbh whats not logical about this. its basically replacing a double socket with a new back dual gang box and then putting a single socket and a fcu. rather than having the plug directly plugged into the socket.
br3ttwilson 12-08-2012 04:22 PM
Google fused connection unit?
rjniles 12-08-2012 04:33 PM
Why should I? You are the one looking for info.
This is primarily a US/Canada based site and methinks you are not in either. Although there is a electrician in France who posts regularly.
Oso954 12-08-2012 05:54 PM
He is in the UK. He is attempting to spur off of a ring circuit.
I guess he doesn't realize that ring circuits are more British than driving on the wrong side of the road.
