Fitting For Outdoor Outlet Box Mounted On Wall - Electrical - DIY Chatroom Home Improvement Forum
Old 06-14-2011, 01:02 PM   #1
I ask the impossible!
Rewards Points: 640
Fitting for outdoor outlet box mounted on wall
So I have one of the cast outdoor surface mount boxes for an outdoor outlet where the wire will pass through the back to the inside. The inspector said it is missing a fitting. What type of fitting am I supposed to use for this?
Please do NOT consider any "before" picture of my house as any kind of endorsement of any particular construction method. In fact, you should probably assume that if I post a "before" picture, I am posting it because I am soliciting advice on a proper replacement for one of MANY things done wrong by a previous owner.
WillK is offline   Reply With Quote
Old 06-14-2011, 01:27 PM   #2
I have gas!
Clutchcargo's Avatar
Rewards Points: 1,312
Does it have the wire-clamp fitting so that you cannot pull the wire out from inside the house?
I tear things down and build them up.
Clutchcargo is online now   Reply With Quote
Old 06-14-2011, 01:47 PM   #3
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
I am going to "assume" the wiring method is romex. If so, use a "romex" connector. If the wiring method is something else, match the connector the wiring method.
electures is offline   Reply With Quote
Old 06-14-2011, 02:00 PM   #4
Licensed electrician
Rewards Points: 1,266
Normally a NM clamp is used without the locknut. It gets threaded into the box. Apply caulk to seal the hole.
electures (06-14-2011)
wall mounted residential toilet kr bennett Plumbing 10 12-05-2010 11:03 PM
GFCI for wall mounted aquarium LOST VEGAS Electrical 4 04-19-2010 07:58 PM
wall mounted toilets pittmatch Plumbing 8 02-05-2008 02:16 PM
Trying to replace wall mounted light fixture jtm2300 Electrical 4 08-03-2007 10:44 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 10:47 AM
