-   -   Fitting for outdoor outlet box mounted on wall (http://www.diychatroom.com/f18/fitting-outdoor-outlet-box-mounted-wall-107653/)
WillK 06-14-2011 12:02 PM
So I have one of the cast outdoor surface mount boxes for an outdoor outlet where the wire will pass through the back to the inside. The inspector said it is missing a fitting. What type of fitting am I supposed to use for this?
Clutchcargo 06-14-2011 12:27 PM
63 Attachment(s)
Does it have the wire-clamp fitting so that you cannot pull the wire out from inside the house?
electures 06-14-2011 12:47 PM
I am going to "assume" the wiring method is romex. If so, use a "romex" connector. If the wiring method is something else, match the connector the wiring method.
Jim Port 06-14-2011 01:00 PM
Normally a NM clamp is used without the locknut. It gets threaded into the box. Apply caulk to seal the hole.
