Old 01-29-2010, 08:40 PM   #1
Fitting dimmer switch to old electrical wiring
Firstly thank you in advance for any advise you can give on this thread.
We have a house built in the 1930's with wiring that went obsolete with the ark. We are trying to replace the existing light switch with a Lolite Light Dimmer switch.
We have found the electrical wiring is fabric coated single wires. The existing switch is a 'RINGGRIP' 5 amp 240 volt light switch. There are 2 sets of 2 wires; negative and positive. One set has a reddish colour so we are presuming this to be positive. The wires from one set (the negative set) go into terminals maked RING and GRIP. The other set is entwined and go into an unmarked terminal.
We have pretty much tried every combination to get this light fitting working. I have attached some photos of the existing and new fitting. Also attached is a sketch of the existing wiring and the instructions that have come with the switch. We have wired the new dimmer switch as per the incandescent lamp diagram on the instructions to no avail.
Does anyone have any ideas or pointers that can help us get this switch working?
Fitting dimmer switch to old electrical wiring-electrical-circuit.jpg   Fitting dimmer switch to old electrical wiring-res01267.jpg   Fitting dimmer switch to old electrical wiring-res01268.jpg   Fitting dimmer switch to old electrical wiring-res01271.jpg   Fitting dimmer switch to old electrical wiring-res01272.jpg
hugomax69 is offline   Reply With Quote
Switch on K&T wiring - OK to pigtail? fdmillion Electrical 4 01-27-2010 10:15 AM
Changing switch for lights in basement, confused on current wiring. RyanD Electrical 2 05-14-2009 09:37 PM
Hunter Fan Dual Switch Wiring Configuration Help schierle Electrical 2 03-29-2009 09:00 PM
HELP! Orange Glow inside Dimmer Switch FranklinD Electrical 10 02-05-2009 07:01 PM
Electrical wiring jonathanm1978 Electrical 1 02-03-2006 12:57 PM
