Have a new flat screen TV that I wall mounted and wanted to install an receptacle behind TV to hide the dangling cord. There was an existing outlet right below my new location. I cut in an OW box behind TV and tried to fish down to the existing receptacle. 2X4 blocking stopped me. Luckily the wall butts uo to a closet. In the closet I cut out a piece of drywall smaller than a outlet cover over the blocking. Fished the wire around the blocking and installed my new receptacle. I covered my hole in the drywall with a blank nylon cover installed horizontally and screwed to the blocking. I also ran the cable TV via the same route.
Thinking about what I have done, have I created a code violation? If so what should I do to correct my install?
technically, the fireblock must be sealed with fire caulk. Not sure if the nylon cover plate compromises the integrety of the fire block but suspect it may. Reparing as yoyo suggested (plus sealing the fire block) would be the best way I can think of.
Cross bracing between studs were named 'fire blocks' in the days of 'balloon' framing as there was no sole plate or rim plate.
Box framing doesn't have an open top and bottom, so 'firestop' is a misnomer. With box framing, the proper term would be cross bracing, rather than fire stop!
not sure where you are at but when the architect calls those chunks of wood fire blocking and they are required to be made with fire retardant treated 2x, I continue to call them fire blocking.
I have seen fire blocking where I saw no purpsose for it but the engineer required it so it got installed. I am an electrician and not a carpenter so there are codes I know nothing about and accept the engineers call.
but, I will accept OP could be dealing with bracing and not fire blocks. Is so, what he did is just fine. If not, it needs to be repaired to its original integrity.
Thanks for all your inputs, The blocking is for the wainscotting on the lower part of the wall. This is a newer house with conventional framing (top and bottom plates) so it is not for fire code. I did not notch the blocking, the cable is in the space where I removed the 1/2 inch drywall and is covered with the blank plate. I suppose I could use a metal blank instead of nylon. Looks is not an issue as this is in a closet.
if this is actually just support blocking, then do what you want with it. If this is in a closet, I wouldn;t even worry about the asthetics and leave it as is.
I see no code violation.
Related Threads
DIY Home Improvement Forum
3.1M posts
319.6K members
Since 2003
