Fishing Wire - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-01-2008, 10:22 PM   #16
Originally Posted by MikeyP View Post
I didn't buy the fan yet. I just read the directions on the outside of the box which said to run it to a 20 amp circuit so I don't know if it has a control switch. What is it?
Some multifunction appliances have a 'special' switch included in the package.
Usually, the package will have a list of components that are included.
If you plan to have a wall mounted switch(s) #12 wire would have to be run from switch box also.
If you wish to have the light and the heater controlled separately, 12/3 would be needed!
Old 12-01-2008, 10:54 PM   #17
Gotcha---What if I want the fan/light/heat on separate switch?
MikeyP is offline   Reply With Quote
Old 12-01-2008, 11:05 PM   #18
Depending on the heater, but some require the fan to run when the heater is on, or it may get too hot.
if this is not a concern, run a 12/2 for the light and 12/3 for the heater.
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Dryer Grounding??? Traci_howdyadothat Electrical 7 05-27-2008 02:14 PM
Installing Fluorescents in Garage rzrbkpk Electrical 26 04-08-2008 10:00 PM
Is regular wire ok to use if fishing through existing walls? slatergrl Electrical 10 02-29-2008 04:47 PM
Stranded wire on screw connections BigJimmy Electrical 7 01-19-2008 03:42 PM
