Fishing Rg-6 In Walls - Electrical - DIY Chatroom Home Improvement Forum
Old 11-15-2009, 08:57 AM   #1
fishing rg-6 in walls
let me tell you direct tv free install has cable running all over the side of the house the 2 bed rooms in the back of the house cable laying on the ground. I was going to fix it put it all under the house and fish it in a wall in each room do i need to put a box in the wall or can i use those things like the phone plate is mounted to just hooked to the dry wall .caddy makes them mp-1. i just dont know if there is supose to have a box or not for coxial cable..
cdundon4va is offline   Reply With Quote
Old 11-15-2009, 10:05 AM   #2
joed's Avatar
Rewards Points: 11,560
No requirement for an actual box. You can use a low voltage ring with a cover plate.
Old 11-17-2009, 06:09 PM   #3
There's a few different kinds of drywall rings. Here's a demo you tube video on the most popular kinds and how they install into the drywall
cochise7969 is offline   Reply With Quote
Old 11-18-2009, 11:27 AM   #4
My favorite low-volt trim ring is the Carlon SC100RR. It has little marking holes so you can get the cut-out just right and it sits fairly flush to the wall. I've used a wide variety of both metal and plastic trim rings and I keep coming back to these. Plus they're readily available at most major hardware stores. I know I sound like a Carlon commercial, but I use these every day in my profession.
Ajax is offline   Reply With Quote
Old 11-18-2009, 11:53 AM   #5
My favorite "trim ring" is a blue electric box with the back cut off
About .22 cents vs the $1 for the orange trim rings
Old 11-18-2009, 12:38 PM   #6
Licensed Pro
Paint options for basement walls and floors 68tele Painting 8 10-28-2009 07:09 PM
removing concrete parging from basement foundation walls. newzev Remodeling 1 07-24-2009 09:17 AM
Is regular wire ok to use if fishing through existing walls? slatergrl Electrical 10 02-29-2008 04:47 PM
Fishing through plaster and lath walls?? slatergrl Electrical 7 02-05-2008 09:29 AM
