Fishing Replacement Wires Thru Inaccessible Spaces - Electrical - DIY Chatroom Home Improvement Forum
Old 11-11-2009, 01:29 PM   #1
Rewards Points: 41
Fishing replacement wires thru inaccessible spaces
I have two ceiling lights both controlled with two wall switches. One light doesn't work, but it's not a bad bulb. I may have a loose wire somewhere behind the drywall or above the ceiling. Trouble is, neither of those spaces are physically accessible to me at all! So how do I fish a replacement wire between the ceiling fixtures and/or one or both of the wall switches?
Right now, I don't even remember how the lights and switches would be connected, physically! How many wires are there, between all four components? I used to remember the wiring for a setup like this but I forgot!
tomseeley is offline   Reply With Quote
Old 11-11-2009, 01:37 PM   #2
300zx's Avatar
Post
Buy a Continuity tester they are cheap and make sure thats your problem they are around $10.00 HD or Lowes
300zx is offline   Reply With Quote
Old 11-12-2009, 06:24 AM   #3
Before busting into your drywall, check the lightswitch. Is voltage present at the switch? If so, bridge the switch terminals with a test lead. Not a bad switch? Check the light fixture connections, socket, etc...
oilseal is offline   Reply With Quote
Old 11-12-2009, 08:10 AM   #4
joed's Avatar
Rewards Points: 12,918
Very seldom do cable go bad. The problem is most likely in a junction box somewhere.
Old 11-12-2009, 08:16 AM   #5
Is it a recessed light?
Check to see if that middle tab (hot tab) has been pushed down & is not making contact
If not, pry it up a little - I'd make sure power is off when you do this
Old 11-12-2009, 09:03 AM   #6
If you can't determine where the problem is, might want to call an electrician.
Troubleshooting is advanced electrical work, but easy for an electrician, so shouldn't cost too much.
And probably not a problem with the wire in the wall as said above (if the wiring was installed to code).
Billy_Bob is offline   Reply With Quote
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 14 01-10-2015 09:08 AM
Wiring Replacement Bathroom Exhaust fan wkend3 Electrical 3 10-22-2009 11:07 AM
Unfused connectors MELTED House wires WHAT TO DO??? jamiedolan Electrical 63 02-12-2009 06:01 PM
replacing outlet with 3 white/3 black wires gpet573 Electrical 4 06-03-2008 02:55 PM
Two black wires with one white! Please help! ibs325 Electrical 15 11-18-2007 09:38 PM
