Fishing New Circuits To Breaker Box In Wall - Electrical - DIY Chatroom Home Improvement Forum
Old 02-20-2012, 12:17 PM   #1
Rewards Points: 26
Fishing new circuits to breaker box in wall
I'm looking to run some new circuits from my main breaker box which is in the garage. I've done this before, but the breaker box was mounted on a basement wall and I had access to all sides of it. This box is flush with the drywall in the garage. Here are two images of the box in the garage, and the view from the attic directly above the box.
I'd like to avoid opening the drywall if at all possible. I was planning to run a fish tape or fish rod from the attic down to the box (or perhaps the other way around) after removing some knockouts from the box. Any advice on this? Seems like I'll just have to "get lucky" and find the knockout.
Since I'll only have access to one side of the knockout (from inside the box), and suggestions for strain relief or cable connectors to transition into the box?
Thanks for any help.
_alphaBeta_ is offline   Reply With Quote
Old 02-20-2012, 12:35 PM   #2
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Does removing the cover allow you enough room to remove a knockout and put a romex connector in there. If it does you could drill a hole on top and fish a wire down into the box. But I would want to try and look inside the wall to see how the wires are stapled first to make sure they are not stapled to where you are drilling.
There may also be a hole that is large enough for another wire in there.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 02-20-2012, 05:30 PM   #3
kbsparky's Avatar
Originally Posted by rrolleston View Post
Does removing the cover allow you enough room to remove a knockout and put a romex connector in there...
Most of the time, I would use a connector designed to be installed from the inside of the panel. No need to fool with trying to install anything from the "outside" with one of those. Just knock out the hole, fish the wire in, and then snap the connector into the hole while threading it over the wire.
Like this one:
More information can be found here.
-KB
The Following 3 Users Say Thank You to kbsparky For This Useful Post:
brric (02-20-2012), J. V. (02-21-2012), rrolleston (02-21-2012)
Old 02-20-2012, 07:58 PM   #4
Pure Genius
Rewards Points: 150
You'll have a little issue w/ the insulation in the wall. What I usually do is knock out a ko. Run fish stick up to attic or down, but pref up. Tape on wire with connector. Fish down. Install lock nut. Done
Dierte is offline   Reply With Quote
Old 02-21-2012, 06:17 AM   #5
A "Handy Husband"
rjniles's Avatar
Rewards Points: 4,172
I would install a 15" spring access panel above the panel. That way you will have future access. About $15 at Home Depot plumbing department.
Coastal South Carolina
Replace masonry wall - feasibility mwpiper Building & Construction 12 01-12-2012 11:36 PM
Trouble with staggered wall rightit Building & Construction 2 03-09-2011 06:23 PM
how to determine if wall is load bearing Tonglebeak Building & Construction 26 01-20-2010 11:26 PM
Temporary wall support question discojv Building & Construction 7 01-25-2009 07:23 PM
Atlantic-need your opinion on markd's comments about my vapor barrier? yummy mummy Building & Construction 11 03-07-2007 09:47 AM
