Fishing Cable - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 03-03-2013, 01:35 PM   #16
Rewards Points: 4,780
It looks OK to code. If you're concerned about that, I suggest you never look behind the drywall. People risk cutting through wires all the time. It's not so much that you're supposed to move wires away from the drywall, it's that you're not supposed to be cutting through drywall when you don't know if there's a wire back there. At some point of course you have to take a risk and at least drill a hole in the wall. Doing this as far from a stud as possible means that if you do touch a wire, it will have a little more room to jiggle, rather than getting cut.
jeffnc is offline   Reply With Quote
Old 03-03-2013, 01:57 PM   #17
Electrical Contractor
jbfan's Avatar
Rewards Points: 140
Originally Posted by sirsparksalot View Post
So you'd drill a big enough hole in order to get a right-angle drill in there? And I was thinking that instead of holes at different heights, I'd just cut across the top of the wall, and two spots on the ceiling. ??
No, I cut a big enough hole to get my hand and drill inside.
It is easier to repair a 12 x 12 hole than it is to to repair a small hole used to notch the joist with.
At the junction of the wall and ceiling, a hole needs to be cut in the wall to be able to drill upwards and a hole in the ceiling to drill the joist and get to the wire.
sound out of cable box amakarevic Home Theater 11 05-18-2012 11:26 AM
Running cable under/around laminate floor greenjelly Flooring 4 08-06-2010 10:49 AM
Need help sizing Generator cable dgajr Electrical 2 07-20-2010 01:07 AM
Evaluating a kinked cable dave11 Electrical 5 05-09-2010 11:20 AM
Underground service entrance cable requirements. kgt55 Electrical 9 06-22-2009 07:55 AM
