Fish Tape Recommendation? - Electrical - Page 2 - DIY Chatroom Home Improvement Forum
Old 11-01-2011, 12:59 PM   #16
Rewards Points: 6,652
Even if you pull one, it will be a problem, due to friction, and that they may have taped the bundle at various points, so that it would be hard to back pull. I would try the fish tape, then go from there.
Old 11-05-2011, 09:16 PM   #17
Easiest
I assume you've already completed this, but if not. Pull from the top down and use wire pulling lube, it should go fairly easy. Unless of course like stated it was taped, although hopefully they knew better than leave wire taped inside a pathway, that is something any data guy should know not to do.
Also the best fish tape for plastic tubing (smurf tube) would be a nylon coated metal fish tape.
hysticali is offline   Reply With Quote
Old 11-05-2011, 10:49 PM   #18
JOATMON
ddawg16's Avatar
Rewards Points: 2,110
Or.....
Tape a rope to the existing Ethernets ( you will most likely have to cut the RJ45 connector off)....then pull all of them out. You will now know exactly how long to make the new Ethernets.
Then use the rope to pull them all back in.....
Oh....and while your at it....add a couple more lines.....I always pull spares.
ddawg16 is online now   Reply With Quote
Scotch Edgelock Tape: My afternoon entertainment bokeh Painting 5 06-20-2011 09:17 PM
Electrical Fish Tape ---Shatter Giles Electrical 7 02-28-2011 08:42 AM
Paint problems....or just problems with the painter... deanswife Painting 5 07-30-2010 08:36 AM
Aged Painting Tape Needs to Come Off user1007 Painting 2 03-04-2010 05:16 PM
Straighten Nylon Fish Tape? fw2007 Electrical 9 03-11-2008 03:58 PM
