Fish Tape Recommendation? - Electrical - DIY Chatroom Home Improvement Forum
Old 11-01-2011, 08:16 AM   #1
Fish tape recommendation?
Hi all, I am looking for a fish tape recommendation to fish a line inside a plastic wire loom, (Orange Tube.). Would the fiberglass one be better? Will the metal one be more flexible? It's a 2 inch wire loom with 6 Cat 5 cables in it, I need to get 2 more cables in it, and the previous installer didn't leave a pull line.
Thanks to all
dataguy is offline   Reply With Quote
Old 11-01-2011, 08:41 AM   #2
Electrician
SD515's Avatar
Rewards Points: 504
A steel one might work, but the longer the distance, the more likely it’ll get hung up. Depends on the head. I’d try a fiberglass one first, if you have one.
Kyle
Old 11-01-2011, 08:58 AM   #3
Licensed electrician
Rewards Points: 1,442
The fiberglass might float on top of the cables, but the steel might be able to push through.
How long is the fish?
A vacuum system might work too.
Old 11-01-2011, 09:28 AM   #4
The fish is from the basement to the 5th floor. Which would be best, fishing from basement up to 5th floor or from 5th floor down to basement?
Thanks,
Old 11-01-2011, 09:29 AM   #5
Rewards Points: 6,652
Fiberglass, but it will be hard with lines already in there. It would be easier to just cascade a switch on the floor that you plan to place more lines on, than trying to fish some new lines up. Especially on the fifth floor.
Old 11-01-2011, 09:40 AM   #6
Electrician
SD515's Avatar
Rewards Points: 504
Straight shot or are there a lot of bends in the run? I would imagine a 2" conduit with only 6 cat's in it should be fairly easy from the fifth floor down if it's a straight shot. With bends and 90's, it's going to be more fun.
Kyle
Old 11-01-2011, 10:51 AM   #7
Yeah, we can't add a switch, we need a home run from the server to the basement and this is the only way, everything else is sealed up!
Old 11-01-2011, 11:11 AM   #8
dataguy, that makes no sense. You can add a switch upstairs, it is done that way all of the time, when lines can not be pulled for more stations. If you have unmanaged switches now, upgrade to either a managed or Smart switch, so you can utilize vlan's.
Look at it this way. Would you rather spend about two to three hours pulling a line, or spend 15 min's hooking up and setting up a switch. Me, I would choose the most simple and easiest option, which is the switch.
Old 11-01-2011, 11:13 AM   #9
I=E/R
a7ecorsair's Avatar
Have you thought about sacrificing one of the cat 5s and using it as a pull line? Use it to pull three cat 5s and a supplemental pull line.
a7ecorsair is offline   Reply With Quote
Old 11-01-2011, 11:18 AM   #10
a7ecorsair, most likely they taped the lines together, to keep them as tight as possible, while pulling. Not using the pull line is one of those things you choose to do, when pulling data. Reason being, is that you look at using a switch most times on certain floors, so that you never have to pull up more lines on a riser. The reason being, the length of pull causes more problems.
In my office that I worked in before the move, we used switches on each floor, with a riser from each floor back to the router, where the data hardline entered the building. A properly designed network from the beginning, with future proof planning involved, works better, than later on, going back and adding more lines the hard way, such as pulling up the riser.
Old 11-01-2011, 11:33 AM   #11
[You read my mind!]
Should I pull from top down?
Old 11-01-2011, 11:58 AM   #12
I=E/R
a7ecorsair's Avatar
If you do use an existing wire make sure is is free. It will take two people, one at each end. You may want to pull just one or two and a fish and then do a second pull.
Old 11-01-2011, 12:02 PM   #13
Okay, should I pull from the top up, or from the bottom down?
Old 11-01-2011, 12:21 PM   #14
dataguy, if it was me, and this is cat-5e, I would just sacrifice all lines, and pull all new cat-6. The problem is, you are going to tear up the outer sheath, and possible tear into some of the individual wire casings, due to friction. I would not even pull a pull string, just pull either one for a backhaul and place a switch to serve all connections, or if sticking with individual runs, pull enough for now, and for the future. That means if there is currently only one jack now at each station, pull two for each station. That would mean at least 12 data lines.
Old 11-01-2011, 12:30 PM   #15
I understand, but these lines are being used and are connected to a patch panel at the top floor, and at the basement level they run somewhere else. I can pull one line down, but all will be a problem.
Scotch Edgelock Tape: My afternoon entertainment bokeh Painting 5 06-20-2011 09:17 PM
Electrical Fish Tape ---Shatter Giles Electrical 7 02-28-2011 08:42 AM
Paint problems....or just problems with the painter... deanswife Painting 5 07-30-2010 08:36 AM
Aged Painting Tape Needs to Come Off user1007 Painting 2 03-04-2010 05:16 PM
Straighten Nylon Fish Tape? fw2007 Electrical 9 03-11-2008 03:58 PM
