First Time Wiring, Seeking Some Input - Electrical - DIY Chatroom Home Improvement Forum
Old 07-22-2012, 08:07 PM   #1
First time wiring, seeking some input
Hey guys, to start I'm 23, just moved into my first house, and hoping to learn a little bit about wiring. One of the immediate things I noticed is that there is not an electrical outlet on the outside patio. However there is a light fixture, and my hope is to run a wire straight down out of the fixture to an external outlet. By doing this I'm trying to avoid cutting or drilling into the brick and running wires through to the switch.
Easy enough, except I'm hoping I can somehow make it to where this outlet gets constant power, rather than having it only get power when the light is on. I'm not sure how to do this. I attached a picture to show what I'm working with. Any help is appreciated!
treardon89 is offline   Reply With Quote
Old 07-22-2012, 08:14 PM   #2
E2 Electrician
stickboy1375's Avatar
Rewards Points: 2,970
Eh, not going to happen, best bet is to just rent a drill and core bore a hole through the masonry.
Old 07-22-2012, 08:17 PM   #3
Ok thanks. That's what I was afraid of.
Old 07-22-2012, 08:22 PM   #4
E2 Electrician
One thing I would look into is a receptacle on the other side of the outside wall, that's where I would drill, this will make life easier in feeding your new receptacle.... If the grout lines are soft it will be easy drilling.
Old 07-22-2012, 08:24 PM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Round weather proof extension box and EMT to a WP box. Then I would take the light off the switch, wire it up hot, and install a photocell in the extension box.
The other option other than installing a photocell, is purchasing a new fixture with a built in motion detector.
Old 07-22-2012, 08:27 PM   #6
E2 Electrician
Just my opinion, but that is going to look ugly as ugly gets.
Old 07-22-2012, 08:32 PM   #7
k_buz's Avatar
But someone with no experience drilling and fishing thru brick is not going to go well.
Old 07-22-2012, 08:42 PM   #8
E2 Electrician
Yeah, I'll agree with that, at least he'll be able to make your idea work with very little skill involved. I get caught up in the aesthetic part of the job.
Old 07-22-2012, 08:57 PM   #9
k_buz's Avatar
Oh don't get me wrong, it wouldn't be my first choice. But my setup sometimes looks a lot more ascetically pleasing when they see the difference in cost.
The Following 2 Users Say Thank You to k_buz For This Useful Post:
LooseSCruz (07-22-2012), stickboy1375 (07-22-2012)
Old 07-22-2012, 09:00 PM   #10
E2 Electrician
I can imagine, I generally don't get the chance to work for that type of cliental, we usually have to bend over backwards and wave our magic wands to make the wiring disappear.
Old 07-22-2012, 09:03 PM   #11
k_buz's Avatar
Now a days, the type of client that is price conscious is the norm vs the one that just wants it done.
Old 07-22-2012, 09:25 PM   #12
JOATMON
ddawg16's Avatar
Rewards Points: 1,444
A bigger issue is that the ckt may not support an outlet.
If that is a light...chances are it's a 15a ckt with 14/2 wiring. Outlets are typically 20a ckts with 12/2 wiring.
You don't have an outlet somewhere on the other side of that wall?
ddawg16 is online now   Reply With Quote
Old 07-22-2012, 09:33 PM   #13
E2 Electrician
Just to be noted, I never use 12-2 except for the required circuits, so to say typical is a little far from the truth.... it's a design choice, You would be much better off with two 14-2 circuits than one 12-2 circuit, just to put it into perspective.
Old 07-22-2012, 10:17 PM   #14
"So I Re-Wired It"
MisterZ's Avatar
Nobody asked where the switch is in relation to this light. Its not likely, but if the switch is on the same wall as the light he may be able to fish a new 14/3 line with some effort.
Personally i agree with kbuz tho. Wire the light hot and put in a sensor light
MisterZ is offline   Reply With Quote
Old 07-22-2012, 10:55 PM   #15
Licensed electrician
Rewards Points: 1,440
I would bet in most houses in America only the code mandated 20 amp circuits are installed and the majority are only 15 amp.
Seeking advice for wiring in hot-tub. YerDugliness Electrical 47 03-17-2012 11:35 PM
Low budget concrete patio, sections at a time... vertigoelectric Flooring 0 01-29-2012 04:13 PM
Mechanical timer wiring? Duane 70 Electrical 5 06-16-2010 08:57 PM
Wiring Tradeline L6006C Aquastat to Lennox CBWMV Hydronic Air Handler VIPSpecialNeeds HVAC 5 03-15-2010 06:37 PM
Garage - Protecting wiring installation eastment Electrical 4 11-26-2005 11:52 AM
