First time with old style fuses in fuse panel
Originally Posted by darsunt
I do switch breakers off and on all the time when lights are on. Is there any risk to this?
No. A breaker is designed to open under load... overload even.
You wouldn't want to REMOVE the breaker under load. This would be the equivalent of removing a fuse under load.
John from Baltimore
One Day at a Time To view links or images in signatures your post count must be 10 or greater. You currently have 0 posts.
"Experience is what you get when you were expecting something else"
"The bitterness of low quality lingers long after the sweetness of low cost is forgotten"
