First Inspection - Electrical - DIY Chatroom Home Improvement Forum
Old 06-01-2012, 11:53 PM   #1
first inspection
What does my electrical need to look like for the first inspection? Am i to put in switches and outlets? Do i even have bar wires showing? do i put in lights? do i need to have the breakers in?
RobertDean is offline   Reply With Quote
Old 06-02-2012, 01:14 AM   #2
Does the wire need to be continues with no bare wires or do i need it to be cut and read for a switch or outlet or light?
Old 06-02-2012, 06:04 AM   #3
DIY staff
Rewards Points: 7,174
Call the building department and ask--
Typically---breaker box--outlet boxes and all wiring is complete--wires or conduit fastened properly
No need for light fixtures or switches and outlets at the first inspection---they will be looking at the parts that will be hidden when the wall and ceiling finishes go on---
I'm not a licensed electrician--one will be along soon---
k_buz (06-02-2012)
Old 06-02-2012, 07:05 AM   #4
Licensed electrician
Rewards Points: 1,622
All the grounds typically need to be made up. I make up all the splices so trimout is easy.
You do not want to install the devices yet. If you do drywall will be harder and the tabs that are supposed to sit on the face of the drywall will be buried.
Old 06-02-2012, 07:57 AM   #5
Cruising into the sunset
JulieMor's Avatar
Rewards Points: 518
Typically there's at least a rough inspection (before drywall goes on) and a final inspection. The inspector needs to see what is going in the walls before you cover them.
But you can always just ask the inspector. He or she will always have the right answer.
JulieMor is offline   Reply With Quote
Old 06-02-2012, 10:49 AM   #6
Lic Electrical Inspector
electures's Avatar
Rewards Points: 1,108
Read post #13 in this thread.
DIY Electrical work in New Jersey
All responses based on the 2011 NEC.
If you live in New Jersey click here. All other states click here.
Please check with local, county and state officials as laws may vary.
Sizing motors here. Online motor calculator here. Online calculators here.
electures is offline   Reply With Quote
DIY Electrical work in New Jersey electures Electrical 42 12-19-2012 03:19 PM
Preparing for Inspection - I pulled the permit diy2morrow Electrical 4 08-17-2011 03:14 PM
Rough-in Inspection Shaotzu Electrical 4 03-31-2011 08:47 PM
Final Inspection Questions docmattman Building & Construction 6 07-15-2010 07:11 PM
Passed my rough inspection, now what? theatretch85 Electrical 12 05-03-2009 02:11 AM
