Firex Smoke Alarm Problem? - Electrical - DIY Chatroom Home Improvement Forum
Old 12-20-2009, 09:49 AM   #1
firex smoke alarm problem?
L have a firex 120-1072b alarm system in my house. I unhooked one in the basement to replace with a cO2 one and found out it wouldn't be compatable with the rest of system so I tried to put original unit back up and when i did it set all units in house off. what happened? left it off to keep peace in house!
cinders is offline   Reply With Quote
Old 12-20-2009, 10:20 AM   #2
dSilanskas's Avatar
alot of times the alarms will set off when you apply power to them. Just let it go for a minute and see what happens. It should stop in a minute. If not the unit you removed might have been damaged.
dSilanskas is offline   Reply With Quote
Old 12-20-2009, 10:31 AM   #3
applying power to one would make them all go off? unit is still good so i don't think that is problem. haven't tried to just let them beep will give it a shot!
Old 12-20-2009, 04:29 PM   #4
Licensed electrician
Rewards Points: 1,632
The smoke alarms should be interconnected so that when one goes off you receive the alarm all over the house. Like someone else applying power may cause a temporary alarm.
Old 12-20-2009, 05:24 PM   #5
Rewards Points: 1,016
When you shut off the alarm in one, the other interconnected ones should stop - but maybe not immediatly, could take a minute or two.
If you just let it go, the one that initiated the alarm should stop after a few minutes on it's own - and then the others will stop as well withing a couple three minutes.
Old 12-21-2009, 05:45 PM   #6
hooked unit up and let it run for about 4 min. finally had to shut it off beeping was driving me crazy!! was going strong when i gave up! now what?
downdraft problem spyshot HVAC 2 10-01-2009 01:56 PM
septic problem??? jjrbus Plumbing 2 09-09-2009 09:59 PM
Weed problem, bug problem, or both? hayzen Landscaping & Lawn Care 1 08-25-2009 06:33 PM
Help with serious flooding problem MNUZZI Landscaping & Lawn Care 12 10-03-2008 02:46 PM
Stymied by window leakage problem. Matth3w General DIY Discussions 5 06-11-2008 06:26 PM
