Fireworks Help - Electrical - DIY Chatroom Home Improvement Forum
Old 06-16-2008, 01:19 PM   #1
Fireworks Help
I am trying to create a fireworks launch pad this 4th of July. I am using 75' of telephone wire to send a charge to ignite this very low gauge wire. That wire will be in the fuses of the fireworks. My issues is I don't know what type of battery (voltage or amperage) to use. I have used a 9v battery but that only work for like a foot of wire. So if somoene could give me an estimate or an idea of a battery that would be great?
lttldude9 is offline   Reply With Quote
Old 06-16-2008, 03:21 PM   #2
Since it is a fireworks fuse I would use a car battery. It might burn the fuse but thats what you want. Right???
BillyD is offline   Reply With Quote
Old 06-16-2008, 05:33 PM   #3
Rewards Points: 266
I did something similar to this several years ago when I put on a fireworks display. What I used for igniters is thin (24-30 gauge) nichrome wire. I twisted it around the fireworks' fuses and attached my leads to the ends. I remember removing it from some heating elements. It is used in most heating appliances. Go to a junk store and buy some cheap appliances such as a waffle iron or toaster. I used phone cable but it wasn't 75 ft long and I twisted some of the pairs of wires together to increase their current carrying capacity. I built a board with some large lighted buttons stripped from an old industrial control panel. The whole works was powered off a standard 10 amp battery charger putting out 12 volts.
Have fun and BE CAREFUL!
junkcollector is offline   Reply With Quote
Old 06-16-2008, 05:36 PM   #4
Have you thought of using model rocket ignitors? I believe you would only need a six volt source to ignite them.
jerryh3 is offline   Reply With Quote
Old 06-16-2008, 07:06 PM   #5
Advice worth 2 cents!
Rewards Points: 150
No No No....don't waste your money.
- Car battery
- #14 Romex
- telephone wire
1) run the romex out to the launch pad..
2) slightly skin the ends of the wire to form a tight loop
3) wrap a small amount of telephone wire around the fuse
4) connect the telephone wire to the romex...
5) touch the romex to the battery....
6) wear safety glasses and no kids.
- pete
ok..if you want to spend money, buy the foot switch that they use for car headlights...
---pete
HandyPete is offline   Reply With Quote
Old 06-16-2008, 07:22 PM   #6
Licensed Electrical Cont.
Speedy Petey's Avatar
Rewards Points: 1,950
Whatever you do PLEASE post a video on YouTube. I LOVE seeing folks get blown up!
Speedy Petey is online now   Reply With Quote
