Firewall Box - Electrical - DIY Chatroom Home Improvement Forum
Old 03-11-2010, 01:51 PM   #1
Firewall Box
Is it ok to cut a small hole in a garage OSB firewall to feed wires into an electrical box?
Do they make firewall rated cut-in boxes?
mopowers is offline   Reply With Quote
Old 03-11-2010, 10:21 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 252
I think if you have osb, you really do not have a firewall.
I thought firewalls were sheetrock.
Old 03-11-2010, 10:41 PM   #3
nap
You talking to me?
nap's Avatar
Rewards Points: 6,290
as I understand, there is fire rated OSB but if this isn't fire rated, I do not believe it carries any fire rating at all.
and btw: the blue plastic electrical boxes carry a 2 hour fire rating. Not sure if the others have the same but I suspect they do.
Old 03-12-2010, 12:28 AM   #4
Registered User
Termite's Avatar
Agreed, if your wall is OSB on studs with no sheetrock underneath, it is not a fire membrane. The code doesn't permit the use of fire retardant treated wood panels for use as a fire membrane in a garage.
As NAP said, nearly all plastic boxes carry a 2 hour rating, which is more than adequate for the 20 minute required separation between the garage and dwelling. Look inside the box you want to use...In the fine print molded into the plastic it should say 2hr.
The building code does limit rated penetrations of firewalls (boxes) to be 16 square inches or smaller holes (2 gang) unless a larger box is specifically listed for use in a fire assembly.
Old 03-12-2010, 08:25 AM   #5
Master Electrician
Rewards Points: 3,764
You may penetrate a fire wall on one side as long as there are no penetrations on the other side within 24" or they are separated by a stud or by using putty pads.
brric is online now   Reply With Quote
Old 03-12-2010, 10:34 AM   #6
Thanks for the input guys. The wall has OSB over the studs, then 5/8" sheetrock over that. The wall separates the garage from the house. I wanted to run a 12-2 cable from the attic and tap into a recepticle on the wall and figured I may have to cut a small hole above the electrical box in order to feed the cable into the box. If I did this, would I be okay with just patching the drywall, or would I have to patch the OSB as well?
Old 03-22-2010, 03:31 AM   #7
Rewards Points: 866
Is your question, in part, whether the OSB is part of a fire rated wall assembly? http://osbguide.tecotested.com/pdfs/en/tb117.pdf
Note that this discusses the use of structural OSB as a substitute for structural plywood. I believe that is what you have. Fire rated OSB, and there is such a thing, is something different.
Klawman is offline   Reply With Quote
Old 03-22-2010, 11:02 PM   #8
I was just wondering if I had to patch any holes in the OSB used to fish wires through. I ended up just patching the sheetrock over the top without patching the OSB. No one will ever know. I don't believe the OSB is part of the fire membrane.
Need advice about waterproofing a firewall. angelo07 Building & Construction 12 01-01-2010 12:34 PM
2 hour firewall separation chawjer Building & Construction 2 06-11-2009 08:58 AM
sheet rock for firewall in a garage sfoderick Building & Construction 4 05-30-2009 03:47 PM
Help! Hole where motor mounts to firewall? she211 HVAC 10 11-11-2008 11:00 PM
Firewall in an existing house mjguff Building & Construction 2 03-11-2008 10:47 PM
