Fireplace Mantel Lighting - Electrical - DIY Chatroom Home Improvement Forum
Old 10-29-2012, 02:00 PM   #1
Hello.
I am in the process of finishing off my basement. For my fireplace, I have installed an 8" x 8" solid oak mantel (reclaimed barn wood). It is truly the centerpiece of the room.
The wall above and below it will be tiled..and there will be one tile under the mantel inscribed with the Family Crest. The problem is, the mantle casts a pretty good shadow on that area and it won't "pop" like I want it to.
Ideally, I would love to install some flush mount lights on the bottom of the mantle. I know I would have to core out some holes and it would be tough. My worry is that there really wouldnt be any airflow once the lights were installed, as the top of the light would be up against solid wood. (if that is even possible).
Any thoughts or ideas or products would be welcomed!
THanks,
Dan
funinthesun2533 is offline   Reply With Quote
Old 10-29-2012, 03:20 PM   #2
Semi-Pro Electro-Geek
Rewards Points: 2,938
You can probably improvise an LED installation that will be plenty bright enough but also produce very little heat and take up very little space.
I am a lawyer, but not your lawyer. And who cares anyways? We're here to talk construction. This is DIY advice, not legal advice.
mpoulton is offline   Reply With Quote
Old 10-29-2012, 04:07 PM   #3
Licensed electrician
Rewards Points: 1,616
Some track light could be aimed at the mantle.
Old 10-29-2012, 04:46 PM   #4
Rewards Points: 13,712
Or recessed cans with eyeball trim rings.
I'd be concerned with installing anything plastic on the bottom side of a mantel.
Old 10-29-2012, 06:01 PM   #5
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
They make a LED tape that would probably work, but it wouldn't look very good. Maybe they make something to cover it, but you'll have to do some looking.
http://www.elementalled.com/flexible...-the-foot.html
Old 10-29-2012, 08:23 PM   #6
dmxtothemax's Avatar
Rewards Points: 5,352
Put in some white leds,
And hide them behind some ornate wood trim.
Very little heat.
Name:  surface mount leds.jpg
Just use a wall wart to power them.
easy as !
dmxtothemax is online now   Reply With Quote
Old 10-30-2012, 09:27 AM   #7
Thanks for all the ideas. What do you all think about maybe a direction "puck" led light under there? If I could core out a hole (according to mfg sizing) 1.5" or whatever it calls for. Then at top of the olde (3" inside the mantle) angle a drill bit to the back of the mantle, which would allow me to run a wire behind the wall over to a led switch?
Would I need to leave some dead air space? For example, if the fixture is 2" tall, core out say 3" leaving an inch of "breathing" room? I could bore out the hole for the power a little bigger than needed to allow any hot air to excape through the top...
Just thinking out loud.
Dan
Old 10-30-2012, 09:54 AM   #8
It wouldn't breathe like that. (Not that an led really needs to) Another option for the led tape mentioned above would be to route a dado in the underside of your mantle and recess it. You only really need a couple watts so it shouldn't be too hard to find something led based that you can conceal.
Good luck an show us pics!
Evstarr is offline   Reply With Quote
Old 10-30-2012, 10:33 AM   #9
Evstar,
Do you think my idea would be safe or should I just go a whole different route? And if so, any ideas on how to remove a cylinder core of wood. I know a hole saw would cut the diameter...but how in the heck to I bust that core out of there?
Before I install anything I should run a fire for a day and see what the temp is on the underside of that mantle. I don't think it will get too hot but better safe than sorry.
Old 10-30-2012, 11:17 AM   #10
My gut reaction is that if it's too hot for the puck light it's too hot for the wood.
Don't know how big Forstner bits come. But that would give you a flat hole. Else a hole saw and chisel would do the job. Drill it an inch at a time and Split the core with the chisel and dig it out. You just don't need to leave a lot head room above. It's not necessary and i don't think you would gain much in the way of heat dissipation. Just enough room for the wire so you can pull it down again if necessary.
Note- I'm not an electrician or a fireplace specialist.
Old 10-30-2012, 10:54 PM   #11
To bust out the inner core of wood,
just use a wood chisel and chisel out from the centre,
it should come out in lumps,
depending on how hard the wood is !
Or you could use a spade bit
Old 10-31-2012, 10:50 AM   #12
So far, this is what I have found that I think would work.
http://www.lightinguniverse.com/unde...ductItemsImage
Not sure if they make a spade bit or forstner bit in that size...I will refer to the google.
The thing I am not sure of is how the light would stay put. I assum it has some kind of clip system for sheetrock but that obviously won't work in my application.
Opinions?
Thanks again!
Dan
Old 10-31-2012, 07:19 PM   #13
For bigger holes try this -
Name:  SPADE BIT 2.jpg
To fasten in the puck light
just use a small screw or nail
thru the side of the light
it doesnt have to be long
6mm would be fine.
or 3/8 inch for imperial.
Old 11-01-2012, 01:31 PM   #14
Well..they do make forstner bits in 1 7/8" which is the diameter of the hole I need. I can horizontally drill over to the cored out area to run the wiring so it would be completely hidden. Now I just need to find a place to put transformer. If I had known, I would have ran cable before I sheetrocked but I am way past that point.
Maybe a false vent in the wall that would house the transformer?
Maybe try to fish a wire back to my control room (would be difficult, not impossible)
Dan
Old 11-29-2013, 08:00 AM   #15
Rewards Points: 194
Did you find a solution? I have the same problem.
sore thumb is offline   Reply With Quote
Building a fireplace mantel shelf NewHomeDIYGuy Carpentry 2 08-20-2012 03:22 PM
Repainting fireplace mantel (HVLP vs Airless) titan7 Painting 5 06-18-2012 08:52 PM
Preparing to redo fireplace mantel, what to expect? kutsyy Building & Construction 14 01-03-2012 03:45 PM
width of fireplace wall w/ brick & mantel ugabulldog Building & Construction 5 07-19-2010 09:16 PM
temper glass for fireplace mantel shelf sil Interior Decorating 3 02-13-2008 08:10 PM
