Fire Sepration Pierced By Raceway - Electrical - DIY Chatroom Home Improvement Forum
Old 08-02-2009, 10:08 PM   #1
Fire sepration pierced by raceway
CEC Rule 2-124 says...."where a fire separation is pterced by a raceway or cable, any opening around it shall be properly closed or sealed in compliance with the Nationa building code of Canada"
What is that rule.. can we just put concrete around it or do we have to use any other material.
is there any rule in CEC about it..
k2hara is offline   Reply With Quote
Old 08-03-2009, 12:46 PM   #2
Rewards Points: 508
Send a message via AIM to theatretch85
I know here in the US where a cable runs through a plenum (air duct) perpendicularly or through top/bottom plates of stud walls, we use a fire caulk to seal around the wire. You should be able to find this at your local hardware store near all the other caulking. I can't say for certain that this would be acceptable in your situation, the NEC and CEC vary slightly in what is acceptable and what is not.
theatretch85 is offline   Reply With Quote
Old 08-03-2009, 01:05 PM   #3
300zx's Avatar
Post
http://www.constructionfastening.com/firecaulk.html
300zx is offline   Reply With Quote
SCARY oven fire! Why did it burn? Beth777 Appliances 73 09-03-2016 02:19 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
Ruud Furnace Won't Fire jasonckcmo HVAC 26 12-01-2009 07:55 PM
why wouldn't circuit breaker prevent fire? fauer Electrical 26 11-28-2008 08:38 PM
