Fire Pump Bypass - Electrical - DIY Chatroom Home Improvement Forum
Old 01-15-2010, 10:21 AM   #1
Fire Pump Bypass
I am a fairly accomplished JOATMAN, but this one has me stumped. Which means it is probably a simple answer!
What is used for the box identified in the pic below? I have read NFPA 20 and NEC 695 (particularly .3 & .4).
Since the tap has to be provided with service rated equipment and installed in accordance with requirements for service entrance conductors, what do you use to make this tap?
I don't want to use the option for a disconnect with an associated alarm. So I am trying to figure out what that 'hard' tap looks like.
FIA Ranch is offline   Reply With Quote
Old 01-15-2010, 11:50 AM   #2
Rewards Points: 58
I think its a contactor. But I have no idea what turns on this contactor. Maybe a "fire"? I am guessing.
Old 01-15-2010, 03:30 PM   #3
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
It's the fire pump controller which needs to be supplied with its own seperate power supply and usually its own meter.
HIVOLT is offline   Reply With Quote
Old 01-15-2010, 03:35 PM   #4
CodeEnforcer
HIVOLT's Avatar
Rewards Points: 99
http://ecmweb.com/mag/electric_abcs_fire_pump/
Old 01-16-2010, 08:04 AM   #5
Let's all give J.V. a nice round of applause! He will be appearing at the Comedy Works all weekend. Call for showtimes.
In a residential application, the fire pump controller is typically "tapped" between the meter socket and main disconnect (as shown), as an alternative to seperate service entrance. The question is how that tap is performed:
1) Without using a non-fused disconnect which requires an associated alarm if the disconnect is pulled.
2) The parts used must be Service Equipment rated.
Sounds like a simple problem, insert a Type 3R junction box and perform the tap. That is until you start looking for Service Equipment rated Power Distribution Blocks (1port to 2port). The Service Equipment rating being required since the tap is ahead of the main disconnect. Haven't found any yet. Hence the question.
Old 01-16-2010, 08:07 AM   #6
Do you mean a transfer switch tied with a generator?
I believe the pump starts on a lose of pressure in the system.
SULTINI is offline   Reply With Quote
Old 01-16-2010, 08:15 AM   #7
are we talking fire sprinklers?
Old 01-16-2010, 08:17 AM   #8
There is a generator transfer switch. But it is associated with the Fire pump controller, which is fed from the tap ahead of the main disconnect.
Old 01-16-2010, 08:18 AM   #9
Yes, that is why the reference to NFPA 20 and NEC 695.3 & 4
Old 01-16-2010, 08:22 AM   #10
why the pump ? not city fed? our suppression systems were on constant
Old 01-16-2010, 08:29 AM   #11
8500 feet up in the colorado mtns. 15,000 gal storage dedicated to fire supression.
Old 01-16-2010, 08:33 AM   #12
whats the prob with alarmed disconnect tied to the alarm company
Old 01-16-2010, 08:41 AM   #13
That is not the type of alarm that the code requires for this application.
Old 01-16-2010, 08:46 AM   #14
there is another post on here where the electric co. allowed a second tap at the meter cab, was poco i believe
Old 01-16-2010, 09:07 AM   #15
That is the easiest way. That was the first choice. Went down that path. Specifically identified "lugs for multiple conductors" are required per NEC, and the rural electric co-op meter panel does not have multiple conductor lugs. So the tap has to be external to the meter panel.
How to find out why your pool pump is not fully priming tripflex How To Guides 8 07-15-2015 06:15 AM
Sump Pump Questions henlij Plumbing 22 03-16-2015 11:00 PM
Low Well Pressure, Submersible Well Pump, Help Please! tpolk Plumbing 7 11-13-2009 07:13 PM
Well Pump Problems dannyjoe Plumbing 6 10-01-2009 07:10 PM
Modification to an existing pump switch DRBLKJK Electrical 10 08-23-2009 04:06 PM
