Fire Hazard??? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-08-2011, 01:00 PM   #1
fire hazard???
We just moved into a new (30 yr old) bungalow. When I went into the attic with an insulation contractor, we found the 27 potlights were not installed properly.
Instead of the ones for insulated attics they were the ones without the extra top to protect against fire. Someone suggested I put aluminum roasting pans on top of the potlights to make it safe but I am not sure. Can anyone help?
sheilalr is offline   Reply With Quote
Old 04-08-2011, 03:03 PM   #2
Rewards Points: 1,520
Yes, you need to get the right lights for contact with insulation or move the insulation from around/over the lights as per instructions.
Keep the roasting pans in the kitchen where they might be useful.
bob22 is offline   Reply With Quote
The Following User Says Thank You to bob22 For This Useful Post:
sheilalr (04-08-2011)
Old 04-08-2011, 03:22 PM   #3
Wire Chewer
Red Squirrel's Avatar
Rewards Points: 46
You need a material that will not conduct heat, but can resist it. Maybe you can use some kind of cement board or something.
Idealy, you'd want to remove those and install new pot lights that are UL approved for use in that situation. A cheap alternative is to use only CFL lamps in them, the heat will not be enough to be dangerous. They can still get rather hot to the touch, but I doubt they can get hot enough to ignite anything.
The Following User Says Thank You to Red Squirrel For This Useful Post:
Old 04-08-2011, 03:24 PM   #4
Licensed electrician
Rewards Points: 996
They don't always need the extra housing. You need to check to see if the housing are IC rated.
If they are not IC rated you will need a 3" clearance around the fixture. This will increase your energy costs do to heat and cold leakage.
Old 04-08-2011, 04:19 PM   #5
Ah ha!
Thanks for your help everyone. I will check the housing and see the rating. Meanwhile, I have spent much time researching this online and found that Amazon.com sells a product that one can install after the fact to solve my problem. It will cost me about $350 but then I will be able to sleep soundly!
The company is called Tenmat and they sell a recessed light cover for about $15 each. I have already ordered them.
So if you hear of anyone else with this issue, please pass it along.
Thanks again everyone. Have a great weekend.
Old 04-09-2011, 10:51 PM   #6
Electrician's Helper
Pudge565's Avatar
Rewards Points: 150
Send a message via AIM to Pudge565
If these lights are not IC rated DO NOT use those covers. Here is why it states, "the Tenmat firebox for recessed lighting and downlights acts as a fire barrier, but also serves as a thermal insulator, significantly reducing air flow and heat loss through the recessed ligth fixture." This is the reason that the non IC lights can not be insulated so that air can circulate around the fixture and cool it off.
There is no such thing as a stupid question, but there is such a thing as an ignorant person, with a question, trying to learn.
Pudge565 is offline   Reply With Quote
Tags
fire hazard , installation , pot lights
Is this a fire hazard and how bad? boxer0987 General DIY Discussions 3 01-18-2011 01:21 PM
Wiring OK? Fire hazard? Wirefire Electrical 19 12-15-2009 02:08 PM
Fire Hazard worry on Low wattage recessed lights usng 50w halogen bulbs jomieblumreich Electrical 7 08-15-2009 05:20 PM
Is this thing safe? possible fire hazard? santawatt Electrical 3 06-25-2008 11:05 PM
Do I have a Fire Hazard with New Recessed Lights - Help! Christy Electrical 8 05-08-2006 08:31 PM
