Fire Caulking Wires In Rated Walls - Electrical - DIY Chatroom Home Improvement Forum
Old 11-15-2010, 10:15 AM   #1
Fire Caulking wires in rated walls
Do you have to fire caulk a wire when it leaves a demising wall and runs into another sheet rocked walls with in a unit from one outlet box to another
rjh333 is offline   Reply With Quote
Old 11-15-2010, 07:09 PM   #2
Do it right.
Could you please clarify the question, I don't understand any of it.
SubSailor is offline   Reply With Quote
Old 11-16-2010, 03:05 PM   #3
Craftsman
Only if building specs or local code say you do!
Superrick is offline   Reply With Quote
Old 11-16-2010, 03:09 PM   #4
Craftsman
Okay, usually not in the same unit only unit to unit or unit to stairwell ect. when specs or local code says and as good practice.
Switch Junction box has 3 sets of 3 wires. Can't get dimmer to work knockout Electrical 14 01-10-2015 09:08 AM
pocket doors ...how to make fire rated clasact Building & Construction 21 03-11-2011 04:46 PM
Insulation of interior walls around fire place ODD Calmeier Building & Construction 5 01-31-2010 05:59 PM
why wouldn't circuit breaker prevent fire? fauer Electrical 26 11-28-2008 08:38 PM
Fire Rated Door - Install window? Git Remodeling 10 08-05-2008 03:32 PM
