Fire Alarm Cable For Speaker Wire? - Electrical - DIY Chatroom Home Improvement Forum
Old 04-02-2012, 09:01 PM   #1
Fire alarm cable for speaker wire?
Hi all,
Can one use fire alarm plenum cable for speaker wire in a plenum ceiling? Will it pass code?
Is CL2 speaker wire rated for plenum ceilings?
Big difference in price!
helpless handyman is offline   Reply With Quote
Old 04-02-2012, 09:04 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
Other than maybe confusing someone, I don't see anything wrong with it.
Old 04-02-2012, 09:08 PM   #3
Thanks,
Old 04-02-2012, 10:08 PM   #4
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
I doubt the quality would be there if it's a really thin wire. I actually had thin speaker cable heat up with a decent size set of speakers and amp. Think it was 20 gauge. Cooked some of the insulation.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 04-02-2012, 10:10 PM   #5
k_buz's Avatar
Fire Alarm wire comes in many sizes...normally, its 16 or 14-2 for the signaling circuit, and 12-2 for the notification circuit...at least for the systems I've installed.
Old 04-02-2012, 10:14 PM   #6
FA wire here is 18/5 or 18/3. It would be acceptable for home theatre in a box type setups but any substantial speakers like #14 much better.
fdiddy is offline   Reply With Quote
Old 04-03-2012, 01:07 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 816
Well....if you listen to Monster Cable....anything less than 4Awg is going to hurt your sound performance.....Monster has to be one of the biggest rip offs there is.
Code....it's low voltage....you can use bailing wire if you wanted....but as K buz noted....if you use something non-standard....a few years from now we are going to see a post here where someone is asking "What are these wires for?"
With that said....do the math.....
If your pushing 200w to the speaker....that is a little under 2A of current....16awg or larger would be more than enough.
If possible...use speaker wire....less confusing in the long run.
ddawg16 is online now   Reply With Quote
The Following User Says Thank You to ddawg16 For This Useful Post:
Ravenworks (04-03-2012)
Is Tray Cable acceptable for Residential use? MisterSteve Electrical 43 02-21-2012 01:35 AM
Wire and Cable Question kbrightbill Electrical 19 02-07-2012 04:02 AM
22/4 or 18/4 alarm control wire? sheslostcontrol Electrical 2 10-27-2010 08:46 AM
fault in old bx 2 wire cable switch loop scire Electrical 1 10-25-2009 02:16 PM
Cable question tommy_vercetti Home Theater 15 09-26-2009 10:10 AM
