Fire! - Electrical - DIY Chatroom Home Improvement Forum
Old 10-24-2013, 10:04 PM   #1
Plumber
TheEplumber's Avatar
Rewards Points: 352
Fire!
I did a call today at a manufactured home.
The GC is a local restoration company. They told me there was a water leak under the home which happens to be 25 minutes off the main highway- another 15 min. to the volunteer FD. Nearest neighbor is 120 acres away.
Fire got through the skirting and melted some pex and ABS drain lines to the laundry.
Besides the service I don't know the extent of the elect. damage.
The first picture is what I first saw as I drove up.
The second picture is the old meter
What would cause this? My guess is the place is around 10 yrs. old
I think what saved the home is the concrete siding.... The lady of the house heard popping, etc. outside and opened the side door to a wall of flames-- that's all the story I know...
Old 10-24-2013, 10:07 PM   #2
Licensed Electrician
k_buz's Avatar
Rewards Points: 2,006
I have no proof, but I have heard that those smart meters can be a problem.
Old 10-24-2013, 10:32 PM   #3
joed's Avatar
Rewards Points: 11,588
Could have simply been a loose connection. I doubt the smart meter had anything to do with it.
Old 10-24-2013, 10:35 PM   #4
k_buz's Avatar
Google it...
http://emfsafetynetwork.org/smart-me...nd-explosions/
As I said, I have no proof, and it would be a long shot, but they have been reported to cause all kinds of problems...or it could be a loose connection.
OP...did you open up the meter socket?
Old 10-24-2013, 10:42 PM   #5
Plumber
Rewards Points: 352
Originally Posted by k_buz View Post
Google it...
Nope, I wanted to get home. Just thought of you guys here and figured I could stir up a little FRIENDLY debate among you sparky's
The Following User Says Thank You to TheEplumber For This Useful Post:
Philly Master (10-25-2013)
Old 10-25-2013, 07:48 AM   #6
Rewards Points: 774
By the looks of the meter can the fire started below the meter, if this is the case.
Are there any connections at the lower portion of this meter can?
What do the conductors look like at the connectors and lower portion.
Look for the major damage, typically that is where the problem started.
Know A Little is offline   Reply With Quote
Old 10-25-2013, 07:52 AM   #7
JOATMON
ddawg16's Avatar
Rewards Points: 824
Is that AL wire?
Old 10-25-2013, 08:13 AM   #8
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
Originally Posted by ddawg16 View Post
Is that AL wire?
Yes looks like it to me.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
Old 10-25-2013, 08:31 AM   #9
PoleCat's Avatar
Rewards Points: 1,646
I think the fire started inside the meter. Based on the soot pattern and conditon of the meter.
"Ask me anything. If I don't know the answer I'll make something up."
PoleCat is offline   Reply With Quote
Old 10-25-2013, 08:49 AM   #10
Rewards Points: 2,630
OK, I read the first few of those stories. They were all by homeowners, newspaper, and television stations. When the conclusions are made by electrical engineers or forensic investigators, then I will be interested in reading some more.
SPS-1 is offline   Reply With Quote
The Following User Says Thank You to SPS-1 For This Useful Post:
Old 10-25-2013, 11:04 AM   #11
Rewards Points: 774
In investigating fire damage look for the most damage.
It looks like the most damage is at that the bottom of the meter can, but it is possible that something in the can dropped down and burnt. Though I am not sure what in the can could drop down?
It would be nice to see the meter can opened.
The Following User Says Thank You to Know A Little For This Useful Post:
Old 10-25-2013, 12:03 PM   #12
Plumber
Rewards Points: 352
Originally Posted by Know A Little
In investigating fire damage look for the most damage. It looks like the most damage is at that the bottom of the meter can, but it is possible that something in the can dropped down and burnt. Though I am not sure what in the can could drop down? It would be nice to see the meter can opened.
Unfortunately I won't return to the job. My work is done there and it's too far off the beaten path.
In hind site I should have investigated more.
We can only speculate now.
I do see the electricians now and then- I'll ask them for more info at some point
The Following 2 Users Say Thank You to TheEplumber For This Useful Post:
Know A Little (10-25-2013), Philly Master (10-25-2013)
Old 10-25-2013, 07:17 PM   #13
Rewards Points: 774
For residential electricians, I assume that is a meter main combo can?
Old 10-25-2013, 07:30 PM   #14
JOATMON
ddawg16's Avatar
Rewards Points: 824
The meter cover is plastic....
Look at the case....see how the bottom portion is white....it got hotter than the upper portion....and since heat rises and the meter is above the heat source....it melted.
If the fire started at the meter, the bottom portion of the box would not be damaged as bad....and those wires would not have all the insulation burned off.
Old 10-25-2013, 07:35 PM   #15
Rewards Points: 774
You are pointing out something I stated in my first post, regarding this topic.
Stripping off old paint blwegrzyn Painting 71 11-28-2013 01:43 AM
Fire Blocking Basement 325_man Building & Construction 20 01-27-2013 09:01 PM
Concrete Fire Pit Project - Advice polizei11 Concrete, Stone & Masonry 2 11-13-2012 03:34 PM
Electrical Fire seansy59 Electrical 1 10-24-2011 06:57 PM
why wouldn't circuit breaker prevent fire? fauer Electrical 26 11-28-2008 09:38 PM
