Finishing Up BoatHouse Install - Panel Question - Electrical - DIY Chatroom Home Improvement Forum
Old 06-03-2009, 10:49 PM   #1
Finishing up BoatHouse install - Panel question
Thanks to all the great advice I've got a pretty good handle on my boathouse feeder installation. I've got my 2-2-2-4 AL buried in conduit and ready to go. Some of these recent threads about AL/CU compatibility has me wondering. Do most if not all of the residential grade sub panels like I would buy at HD/Lowes have lugs and/or main breakers compatible with AL? I guess I would have to be concerned about the Neutral and Ground bars too. I know to use the anti-ox goop (I used it on my original 200A house panel upgrade that ya'll helped me with last year), but I never considered the AL rating on panel and breaker lugs before. Lowes has an inexpensive Siemens panel combo right now on sale. 100A w/ 5 20A breakers, but I can't find any detailed info online about the CU/AL specs.
robertmee is offline   Reply With Quote
Old 06-04-2009, 05:29 AM   #2
Electrical Contractor
wirenut1110's Avatar
Rewards Points: 510
Send a message via AIM to wirenut1110
Yeah, you'll be fine. I can't recall ever seeing a panel, breaker, ground/neutral bar rated for copper only.
wirenut1110 is offline   Reply With Quote
Old 06-04-2009, 10:35 AM   #3
Rewards Points: 130
AL is fine to terminate in most any panel. The lugs in the panel are usually AL themselves. Some higher end panels will have copper buss bars and lugs.
When using the Noalox, rub it into the strands of the conductor and put a dab in the terminal lug, so the inspector can see it.
Old 06-04-2009, 11:21 PM   #4
Thanks guys!!
Old 06-07-2009, 12:56 PM   #5
Got a call from our neighbor up there. Rained 6" and our entire ditch is washed out from the house down to the level portion of the run. Crapola!! Any suggestions on what to fill the ditch with to help erosion? Bricks or Rocks?
Old 06-07-2009, 01:39 PM   #6
Rewards Points: 2,350
Just more dirt. You have to pack that stuff in layers. Add dirt and tamp it down, and add more dirt. Add dirt and tamp until it is full and tight.
Old House Rewire finnimus Electrical 15 05-13-2011 10:39 PM
Garage Wiring issues jimmyfloyd Electrical 20 06-08-2009 02:57 PM
Sub Box Install Question epeterson777 Electrical 11 02-01-2009 02:13 PM
Bypass Shower Doors Install Question houston Kitchen & Bath Remodeling 4 01-31-2009 07:55 PM
main breaker panel terminology question! jeffjohnson1 Electrical 3 09-30-2008 08:04 AM
