Finishing Basement And Need To Add Subpanel - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 02-06-2013, 10:22 PM   #31
Electrical Contractor
rrolleston's Avatar
Rewards Points: 1,012
Send a message via AIM to rrolleston Send a message via Yahoo to rrolleston
You should be fine I see some 100 amp breakers having lug capacity up to 1/0 and for the ground and neutral wires you will have to get ground and neutral lug that screws into the ground/neutral bar.
With Electricity there is the right way to do it and the dead way. Just because it works does not make it safe.
rrolleston is offline   Reply With Quote
The Following User Says Thank You to rrolleston For This Useful Post:
muellertr (02-06-2013)
Old 02-06-2013, 10:39 PM   #32
rrolleston's Avatar
Here is a picture of what the lugs may look like.
Old 02-06-2013, 11:31 PM   #33
" Euro " electrician
frenchelectrican's Avatar
The photo on the left if that is correct model that is AN70 it will have small forks that use two netural openings. (it will take up to #2 conductor size )
The Lug on the right side is larger one which we useally call AN100 that can take up 1/0 some case 2/0 AWG size and there is interal screw inside you will have to unscrew the hex screw out first then take care the interal screw first.
Note: make sure that is seated on the bussbar correct otherwise with a good load it can overheat pretty fast and have a open circuit like open netural on MWBC.
Both items you should able find them in big box store and you have QO panel so use the SqD items due they are spaced properly for this load centre.
Merci,
Marc
Old 02-06-2013, 11:32 PM   #34
awesome, thank you so much..and to everyone...
so can i use that 4 wire aluminum, 2-2-2-6 and put that to both panels without needing to worry about special connections... sounded like some things needed to be rated for aluminum, but are the panels fine by default?
muellertr is offline   Reply With Quote
Old 02-06-2013, 11:34 PM   #35
That is not a issue due both panels are rated for alum ou copper.
But if you going to use the alum conductor the only extra item you will have to buy is antioxide paste tube.
Merci,
Marc
Old 02-07-2013, 06:14 AM   #36
Rewards Points: 756
Originally Posted by NJMarine View Post
In stead of runnuning individual conductors, you could run 100 amp SER. Which is 2-2-2-6 aluminum conductors.
Now I gotta ask how we determined that #2 aluminum is good for 100A?
Mark
busman is offline   Reply With Quote
