Finished Generator Project - Electrical - Page 3 - DIY Chatroom Home Improvement Forum
Old 09-10-2012, 09:03 AM   #31
raylo32's Avatar
Rewards Points: 1,238
As promised here are some pics of the black steel install.
Supply end with union to allow stop valve servicing if necessary.
Piping run
2-Way manifold with drip leg
Generator connection
Grill connection
Live long and prosper.
raylo32 is offline   Reply With Quote
The Following User Says Thank You to raylo32 For This Useful Post:
mpoulton (09-10-2012)
Old 09-10-2012, 09:12 AM   #32
Rewards Points: 344
VERY NICE! Glad to see you used dope instead of tape. Was the leg for what looks like a grill part of the original setup?
herdfan is offline   Reply With Quote
Old 09-10-2012, 09:14 AM   #33
Rewards Points: 3,256
More better. That pipe dope must transfer by osmosis like heat sink compound and anti seize.
zappa is offline   Reply With Quote
Old 09-10-2012, 09:47 AM   #34
raylo32's Avatar
The grill leg was the original install but it was copper. That's why I originally did the generator in copper just adding it onto the existing. I did reuse the grill stop valve with the steel piping. It looks old but seems to work well.
Old 09-10-2012, 09:50 AM   #35
raylo32's Avatar
That's a geat analogy with the anti-sieze. Like the pipe dope it seems to have legs and once it is in your carpet forget about it. This dope was really messy partly because it is white (Hercules Real Tuff teflon). I'd wipe a joint with a paper towel and then couldn't see where on the towel the dope was. Pretty soon it was everywhere.
(Partial) Radiant Barrier Above Finished Attic? Lascaux Insulation 11 09-26-2012 08:56 PM
Finished basement humidity at 80% for unknown reasons denemante HVAC 6 05-07-2010 04:33 PM
Moving ductwork to accomodate finished basement Badfish740 HVAC 1 01-13-2010 04:11 PM
OK to do a short, unsupported, vertical run of romex in finished wall? TomServo Electrical 2 10-04-2009 08:43 AM
Finished attic humidity? kcrossley2 HVAC 2 08-11-2009 06:06 AM
