Finding Unused Wires From Breaker Panel - Electrical - DIY Chatroom Home Improvement Forum
Old 10-06-2011, 04:20 PM   #1
Rewards Points: 87
finding unused wires from breaker panel
I was looking in my breaker panel and found a 20 amp breaker that was labeled back porch, but was crossed out and said not used. Everything on the back porch works, what would be the easiest way to find those wires running to the not used breaker?
Roundeye is offline   Reply With Quote
Old 10-06-2011, 04:27 PM   #2
Electrical Contractor
jbfan's Avatar
Rewards Points: 650
Breaker on or off?
I find breakers listed like that all the time.
Open the panel and see if the breaker has a wire on it.
Old 10-06-2011, 05:05 PM   #3
Rewards Points: 87
The breaker was on, I turned it off and there's a wire hooked to the breaker, I was wanting to find the wires and reroute them to the bathroom for a wall heater.
Old 10-06-2011, 05:08 PM   #4
Licensed electrician
Rewards Points: 1,884
Follow that wire up to where it exits the panel and try to visually track where it goes.
It might just be easier to run the new cable and skip messing with the old stuff.
Old 10-06-2011, 08:07 PM   #5
Missouri Bound's Avatar
Is it cable or thhn in conduit. If you can isolate the wires, hot neutral and ground from the panel, then you can attach a tone to the wires and find it with a probe. The tone generator must be used on an UNenergized circuit.
breaker panel Ehren51 Electrical 3 01-20-2015 05:23 PM
Bad breaker panel??? drjay9051 Electrical 9 08-25-2010 03:43 PM
15 AMP GFCI and breaker panel 8roty Electrical 6 01-04-2010 07:10 PM
Portable breaker panel? minameismud Electrical 15 02-24-2008 12:57 PM
Need help finding Square D breaker jmyers34429 Electrical 5 01-30-2005 05:02 PM
