Finding Underground Electric Wire For Driveway Lights. - Electrical - DIY Chatroom Home Improvement Forum
Old 11-01-2008, 04:44 PM   #1
Unhappy
Finding underground electric wire for driveway lights.
My house is 22 years old. The house originally had driveway lights along the driveway that curved around the fron of the house and the straightaway to the garage. These lights have a 3"x5" metal box attached at the bottom. The lights are turned on by a wall switch in the foyer. None of the lights sits up straight; the metal boxes with attached lights are leaning terrible. Additionally, 3 of the lights were knocked out by the snow plow guy about 8 years ago. The wires were capped off. Over the years, the lawn has grown over and we no longer know where these wire locations are. I want to add lamposts to the ends of the driveway for lighting and get rid of the leaning little lights. The closest place to run the electric to the lamppost is from one of the missing lights. Is ther any way to detect where that electrical wire is? I don't want to have to dig up the lawn all along the driveway to find the wire. To use any of the other lights for connecting the lampposts would require tunneling under the driveway which the electricians tell me would be costly. Please help!
mitch21131@verizon.net
mitch21131 is offline   Reply With Quote
Old 11-01-2008, 04:51 PM   #2
A metal detector would give you a good idea.
There are also utility locater's that do this service if you can't get a hold of a metal detector.
My idea of a perfect day: No where to go and all day to get there.
Marvin Gardens is offline   Reply With Quote
Old 11-01-2008, 05:16 PM   #3
1610 CUB's Avatar
Rewards Points: 150
I would think that the installer would have put the lights in equally. Every 6 or 8" or so? Measure any two and you can find the missing ones. When you get close use a probe (chop stick) gently pushed into earth till you find the wire. Thats how I would look for it anyway j
1610 CUB is offline   Reply With Quote
Old 11-01-2008, 06:12 PM   #4
Lights not evenly spaced
The lights were not put in at even intervals. They were not even put in the same distance from the driveway edge - they are anywhere from 3' to 5' from the driveway edge.
Old 11-01-2008, 06:56 PM   #5
If the lamps are drawing current you can make a 12" dia. wire loop with many turns, hooked to headphones, and then (in principle) you will hear the 60 Hz hum.
The magnetic field given off by the cable may penetrate quite a few inches of dirt.
Also, some studfinders have a wire finding feature but this is not tested for earth penetration.
Old 11-01-2008, 08:57 PM   #6
Eibwen
Dowse for em!
Take two steel wire coat hangers and cut/shape them so you have an "L" with about three inches on one leg and 7-8 inches on the other leg..
Bend the long part of the L so that it is a little more than 90 degrees.
Hold the two short sides loosely, one in each hand and allow them to droop slightly in front of you. Walk slowly across the yard. As you approach a buried pipe or wire, the hangers will rotate in your hands and attempt to align with the buried line. Try it from two directions across the yard and mark each time you locate something.
Works better on a wire carrying current but it will also locate water pipes, catv cables etc.
It really works and is not a joke!
Sammy is offline   Reply With Quote
Old 11-02-2008, 05:49 PM   #7
Originally Posted by Sammy View Post
Dowse for em!
I will vouch for what you say!
Over the course of my life, I have had reason to locate buried cable and water etc.
Although, I used magnetic field detectors of various sorts, I always verified the findings by using #10 copper wire bent in an 'L' shape.
I have even used them to find water, before digging a well. And had 100% success.
I believe that the earths magnetic field is distorted by buried objects, and the wires dangling down, are affected by this distortion.
Old 11-02-2008, 07:30 PM   #8
Eibwen
I have found buried lines using that method that utility locators have missed.
Never have tried copper wires though.. Just used coat hangers cause they were handy. Hmmmm.
Although back in my treasure hunting days I have heard people say they would coat the tips of the wires with gold if looking for gold etc.
Old 03-10-2011, 06:02 PM   #9
Those of you who can find wires and pipes by "dowsing" (using those metal rods) should run, not walk, to claim the $1 million dollar prize that the James Randi foundation offers to anyone that can demonstrate abilities like this. FYI, it's been unclaimed for many years, despite thousands of people trying (not just dowsing, but other "paranormal" activities as well).
gregmac is offline   Reply With Quote
The Following 2 Users Say Thank You to gregmac For This Useful Post:
Leah Frances (03-10-2011), mpoulton (09-24-2012)
Old 03-10-2011, 08:42 PM   #10
Scared Electrician
Saturday Cowboy's Avatar
THANK YOU. se the wikipedia article on the idio motor effect http://en.wikipedia.org/wiki/Ideomotor_effect
Ragged Trousered Philanthropist
Please follow the code - its there for your safety no matter how inconvenient.
Saturday Cowboy is offline   Reply With Quote
Old 03-10-2011, 09:05 PM   #11
Learning by Doing
Leah Frances's Avatar
Good first post, newbie!
If I could only remember to THINK about what I was doing before I did it.
Leah Frances is offline   Reply With Quote
Old 03-10-2011, 11:16 PM   #12
Thanks for the link, it will be money in the bank for me! I'll be signing up immediately!
I made my living as cable locator and I never had a cable damaged by an excavator.
There are commercially built cable locators available, that work in much the same manner a military mine detector.
During my working career I always used electronic detectors and backed up the results with copper rods.
Using these rods isn't witchery, or magical. We live in a world that has magnetic lines running between the north and south poles. Our world is polluted with magnetic lines. Some are natural and others man made.
Magnetic lines of force are used to make electric motors run, in directional compass's etc. It not a large leap to make a pair of copper wires move in your hand, in much the same manner as magnetic lines cause the copper wires in a motor to move.
Every human being on the earth can be taught to detect the warp of magnetic fields. Its this warp that is the key to the function.
I checked out the link and much to my disappointment, the money is to be paid for demonstrating paranormal ability.
Sadly, using a pair of wires to detect variations in magnetic lines of force, isn't paranormal.
Old 03-10-2011, 11:46 PM   #13
Learning by Doing
:whistling:
Old 03-11-2011, 01:13 AM   #14
Scared Electrician
except copper is uneffected by magnetics
and by their definition dowsing is paranormal.
Old 03-11-2011, 07:17 AM   #15
Rewards Points: 1,214
"Even by using # 10 copper non magnetic ? "
COLDIRON is offline   Reply With Quote
hooking up dryer....bronx ny code SURFBUG Appliances 6 10-14-2008 10:41 PM
Design an outside underground electric system??? antiqking Electrical 6 09-13-2008 11:28 AM
how to wire an electric heater murray59 Electrical 8 04-26-2008 12:21 PM
Installing Pot Lights - 12AWG and 14/2 wire ... help! njchan Electrical 4 04-10-2008 07:50 PM
burying wire underground amakarevic Electrical 42 03-16-2008 03:04 AM
